Mercedes-Benz Warranty
Old Dec 12, 2006 | 12:08 AM
tee_tz's Avatar
ML63 AMG
Guys, I didn't know Mercedes-Benz didn't cover brakes in it's warranty?? Is this true, I could have swore I heard my salesman tell me it was part of the warranty (48 Months/50,000 miles).
Anyway, so my brakes are grinding, and I'm not sure if this is the problem: a couple of weeks ago I swapped my Mercedes 16" Wheels for the Mercedes 17" Sport Wheels. Almost instantly the front brakes began making a little noise; I should also mention that I used the bolts from my 16" Wheels, didn't get new ones with the 17" Wheels. Please advise.
Tee_Tz.
Old Dec 12, 2006 | 12:40 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
noise doesn't mean brake is bad
sometimes it's just dirty
and I don't know if the bolts are the same, but since it's mercedes brand wheels, it's most likely the same
but you might want to check the length to make sure.
Cause I know the 16" wheels has very long bolts, I don't know about 17". Just double check to be save
Old Dec 12, 2006 | 02:37 AM
white_w203's Avatar
is SOLD
i dont think the brakes are covered since it is wear and tear and its always different depending on the person's driving style.
as for the bolts im pretty sure u can use the same bolts because its oem.
Old Dec 12, 2006 | 02:47 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
brakes were never covered by the warranty. it's just the service A and B. it's not a bmw... haha
Old Dec 12, 2006 | 03:48 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
so bmw warranty covers brakes??
if that's so, then it's good for u, cause m3 brakes are pretty expensive
Old Dec 12, 2006 | 04:04 AM
nlpamg's Avatar
haha, yep! that's pretty much a big reason why I chose the m3 over the cayman S and slk55, it'll be a lot cheaper to maintain (not to mention a little cheaper on my monthly).
Old Dec 12, 2006 | 04:08 AM
nlpamg's Avatar
Tee_Tz.
hmm, I'm not sure how long the bolts are supposed to be for the 16's and 17's, did you check the offsets? how many miles do you have on the car? my front brakes haven't lasted more than 22k miles. perhaps the larger/heavier wheels led to the brakes wearing down quicker. I know that going from 17 to 19 did that for me.
Old Dec 12, 2006 | 08:30 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Yup, only BMW has the included maintenance now...who knows if they will follow suit like MB and Audi has. Good thing I bought mine when warranty covered wear and tear items, free brakes FTW
Tee_tz, if your brakes are defective in a way, then yes, MB should cover them but as far as normal wear and tear, its on your own dime
Old Dec 12, 2006 | 08:55 AM
victorfjr's Avatar
2002 C230 coupe
I don't know if it's just in Canada but my front brakes were changed (pads and rotors) within the first two years for free. The service guy told me they were covered under the wear and tear but only for the first two years.
Old Dec 12, 2006 | 09:44 AM
BKLYN_C's Avatar
MB
Changed my front brake pads at 21,000. First i thought there was something wrong with the pads or my driving style, but the service advizer at MB said that milege is normal for 05 C230 with larger rotors.
Old Dec 12, 2006 | 09:48 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Do you do a lot of city driving/stop & go traffic? If you do, probably normal but if you do a lot of highway driving, then it might seem abnormal. 52k on my car and still on original front pads w/ 9mm left in thickness (14mm new).
Old Dec 12, 2006 | 09:56 AM
BKLYN_C's Avatar
MB
Most of the time driving in Manhattan and Brooklyn. Stop and go all the time, even when I get on the highway, don't see much difference because of truffic
Old Dec 12, 2006 | 09:59 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Ah, good 'ol NYC traffic. That'll do it
Old Dec 12, 2006 | 10:01 AM
c230k sport's Avatar
2009 C63 AMG
Hi All, just bought my first MB (2005 C 230 Sport) the other day and I am thinking of adding some performance mods. Stupid question though...does adding performance mods void your manufacturer's warranty?
Thanks.
Old Dec 12, 2006 | 01:03 PM
tee_tz's Avatar
ML63 AMG
Damn! Damn! Damn! I was used to the BMW Warranty -- brakes start squealing, I've got the dealership on speed-dial! They change them for free! About a year ago the tranny was acting up, they changed the whole entire thing - I just signed and drove out.
This sucks, I don't have much miles on the car, only 34,000 and I'm not aggressively braking or anything, so I'm thinking it can't be the brakes. Hmm... or could it?
How much are new brakes?
Tee_Tz.
Old Dec 12, 2006 | 01:07 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Stealership quotes for front brakes are usually between $500-$700, depending on the labor rate, etc.
Old Dec 12, 2006 | 06:22 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
damn you barely brake it??
Old Dec 12, 2006 | 06:23 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
Tee_Tz.
if it doesn't cover in warranty, then just buy the parts urself and take it to other shops, u'll save at least half that way
Old Dec 12, 2006 | 07:29 PM
MercedesFTW's Avatar
Cee Fiddy Five
Brakes aren't that hard to DIY right?
I mean my friend switched out his old stock A4 front brakes with some Brembos...and he seems pretty inept.
Old Dec 12, 2006 | 09:55 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
hahaha, 90% highway driving man, only need brakes for slowing down or off ramps
I figure, I can get probably 60k or a little more on the pads then upgrade time
Old Dec 12, 2006 | 09:56 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Its not that hard to do yourself, there are tons of tutorials online and the forums on how to do that. Save yourself a bundle by DIY.
Old Dec 12, 2006 | 10:11 PM
03see2thirtyk's Avatar
03 w203
I changed my brakes twice in the past, once on a corolla and second on a prelude, when I found out that the service advisor wanted to charge me around $600 for just replacing front pads, nothing was wrong with rotors, just imagine if I needed to change those how much he would have quoted me. Anyways I learned quickly how to search these forums on how to replace the breaks, My main fear was the menu telling me my breaks were bad, and for the 03 w203 its just a little part you can buy at the dealer. I think I got sensors for $13.
Old Dec 12, 2006 | 10:17 PM
moosejaw's Avatar
none
Has Audi discontinued free service as well?
Old Dec 12, 2006 | 10:26 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
They did for 2007+ but they offer a great maintenance package for $550...which includes the 4 years / 50k scheduled services. So that would be one service a year...saves a lot of money and has been a great seller. MB should do something like that and offer a maintenance package.
Who knows when BMW will be the next to do away with free maintenance...
