Johnand's 2007 C230 thread
#377
Super Moderator
2007 C230SS; 2014 ML350 BT
Front pads finally worn out!
Finally after 5 1/2 years, and 105K+ miles, I managed to wear out the FACTORY front pads:
![](http://w203.jgatek.com/gallery/var/resizes/Brakes/IMG_0909.JPG?m=1346174404)
Mileage when message popped up:
![](http://w203.jgatek.com/gallery/var/resizes/Brakes/IMG_0910.JPG?m=1346175136)
I had the front wheels off this last weekend to rotate the tires side to side, and check the brakes. I also threw a micrometer on the rotors and they were worn to 26.035mm and 26.010mm and the minimum is 26mm, so that is perfect wear to replace the rotors every pad change.
I have new factory rotors and new Carbotech pads waiting to go on. I was going to go with the Akebono Euro Ceramic, but decided to go with Carbotech, as I used them on my Sentra and Jeep with great results, and I have a buddy that works for them. I had already bought the Akebono's, so I have a set for sale if anyone is interested.
I have actually been looking forward to wearing them out, as I want to get rid of the horrible brake dusting of the factory pads.
So, look for a post and write-up when I replace them shortly.
#380
Interesting that the 07 simply says "Brake wear" while my 05 instructs me to a workshop. And yes the life you got from them was amazing. By 100,000 miles my car had gone through two sets of rotors and three sets of pads.
#381
Super Moderator
1)My commutes are 90+% highway mileage with little to no traffic congestion. Though, the last few months we changed our hours and am driving in rush hour traffic, so LOT'S of stop and go. I noticed the wear increasing at a much higher rate recently.
2)The 7G is very good at downshifting on it's own to provide very good engine braking. Because of that I use the brakes very little in normal driving. I also use the manual touch shift to downshift a lot.
I regularly push the car, so it is not from driving like a little old lady.
#383
Super Moderator
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#386
Super Moderator
I have been the last couple of months, as the weather has been good. Plan to drive it during the summer, and the Tig during the winter.
Not that is matters much as the paint is all rock chipped anyway![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Probably continue to drive it through September, then set it up in the garage for the winter and do the brakes, transmission service, differential service, and possible suspension refresh. Get it ready for spring.
#392
Super Moderator
I think the dampers are shot, as I get some bounce when coming to a quick stop, and they just have become flacid
The roads here are horrible and really hard on dampers.
Plus, I get some occasional popping in the front end while turning and transitioning driveways, which I think is swaybar endlinks or thrust bearings in the struts.
#394
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
#395
Was that all you replaced? I just replaced the caster and camber bushes.. I hate to re-do all of that so quickly. I thought I'd need to replace both upper and lower control arms, strut mounts, front struts and rear shocks at minimum. My car's dampers are definitely bad. I'm a good distance ahead of you guys in mileage, but the roads here are not too bad.
#396
Super Moderator
So I am in Michigan on business and I get a call last night from my wife, that when she was stopped at a light, the transmission jerked, and when she pulled away from the light, the transmission wouldn't shift up. So, I assume it went into limp mode. Told her to pull into the next parking lot, and turn the car off and restart and see what happens. She did, and made it home w/o issue.
So, I am pretty sure when I scan the car with DAS I will get the dreaded speed sensor error. Time for a conductor plate replacement. Problem is, I was told last time at the dealer that I needed to replace the valve body assembly to the newer one to fix the conductor plate issue. Was quote around $2K.
The weird thing is, I just did the 3rd transmission service about 300 miles ago.
#399
Super Moderator
Finally getting new brakes
So, after driving around with "Brake Wear" on the MFD for another 5K miles, I figured, I should finally take care of that.
I added a little bling to the brake job, and here is a teaser pic:
![](http://jgatek.com/mbworld/IMG_0407_TMB.jpg)
The picture doesn't do it justice, but that is a color matched Diamond Black Metallic caliper.
More pics and details to come when the job is finished.
