Life After Warranty
Subscribe
Dec 16, 2006 | 02:47 PM
I have a 05 C230 Sedan with 53,900 miles. I bought it October of 2004. I have been through a full set of tires and I just bought my 5th and 6th tire. Thanks to the tire thread I saved a few bucks. I put 2 BF Goodrich G-Sport tires on the rear for $250 out the door. Other than tires I have put front brakes on myself.
I have always taken my car to the dealer for scheduled maintenance. So far I have had no service problems with my car. I am wondering....now that I am out of warranty, should I be on the look out for anything. Is there any preventative maintenance that I can perform to ensure my good fortune when it comes to repairs?
Reply 0
Dec 16, 2006 | 03:24 PM
thing will just start to break down when time comes.
but it prob won't be happening for another 40k+ miles
or you can get extended warranty
Reply 0
Dec 16, 2006 | 04:23 PM
Nope. I drive too many miles. They wanted $4,000 for another 50,000 miles. At the rate I am going I will pass that in a few months. Plus I have had such good luck I figured I would save the 4k until something went wrong. Was that a bad gamble? I just figured that it would be better to spend the 4k directly on a repair than on an extended warranty that I might not use.
When things start to go wrong....what are the usual things that I should expect to see?
Reply 0
Dec 16, 2006 | 05:15 PM
i don't know about w203
but for example on my bimmers
from about 100k and on
you will see these types of problem, these are the short list of what i repaired on my bimmer
entire transmission, radiator, coolant expansion tank (basically I replace everything related to coolant), flex disk, valv cover gasket, oil pan gasket..etc
if the tranny doesn't go out, then 4k will be more than enough to fix these
Reply 0
Dec 16, 2006 | 05:34 PM
If you've had good luck with the car so far, bank the $4000 in an ING account and earn some interest while its there. More than likely, repairs won't get near your savings amount.
I'm at 52k on my A4 that I got Sept 2004 and am in the same boat as you.
Reply 0
Dec 16, 2006 | 05:37 PM
good thing is that i have 6years 100 extended warraty for MBUSA
still more then 55k to go
Reply 0
Dec 16, 2006 | 09:23 PM
a suggestion>>>>>>>>>>>>>>>>>>
Quote: I have a 05 C230 Sedan with 53,900 miles. I bought it October of 2004. I have been through a full set of tires and I just bought my 5th and 6th tire. Thanks to the tire thread I saved a few bucks. I put 2 BF Goodrich G-Sport tires on the rear for $250 out the door. Other than tires I have put front brakes on myself.
GeT A QUOTE FROM WARRENTY DIRECT.COM YOU MAY BE PLEASANTLY SUPRISED. I WAS.
Reply 0
Dec 16, 2006 | 11:43 PM
Be afraid.
Very afraid.
Reply 0
Explore
Subscribe
Currently Active Users (1)
