Rookie Question on Brakes.
Old Dec 29, 2006 | 01:30 AM
METC240's Avatar
2005 C240 4Matic
I hear my brakes and am not sure on a few things. I tried te search but very little came up. I have a C240 4 matic and well...
1. where can I get the parts I need, looking to upgrade if possible the rotors to x-drilled or slotted if possible... not looking to go big just subtle upgrades / looks.
2. recommendation on the pads and again where can I get them on line?
3. does anyone know a local shop near Edison / Metuchen NJ
Thanks a lot guys for this. I tried the local MB dealer and the total for them to do the work was $780.00 I am going to another dealer but still think it's kinda high...
Thanks in advance for the help...
Old Dec 29, 2006 | 08:03 AM
C24owner's Avatar
'08 E550 4Matic
Go with Brembo rotors (x-drilled) and mintex pads for the front and Axxis pads for the rear. They are low dust and low noise.
You can get rotors and pads here.
http://www.brakeworld.com/
Old Dec 29, 2006 | 02:38 PM
Buellwinkle's Avatar
If you like the look of the sport sedan brakes, you can order the rotors, pads and calipers, probably about $800 for the bunch. The C32 brakes are nice, says AMG on them and are 4 piston. The 2005 and newer brakes look similar but are 2 piston brakes. I use Duval Motors for online genuine MB parts (check my website for the URL). The MB pads for the C32 are low dust compared to what you have now.
FWIW, my dealer quoted yesterday, $122 for rear pads and $149 for front pads installed on my SLK230 which has brakes similar to the C240. Don't know where some dealers get off charging $780, ouch!
Old Dec 30, 2006 | 12:45 AM
METC240's Avatar
2005 C240 4Matic
thanks, I am not sure on the rims and the clearance for the 4 piston setup. is there a way to check? I do not have the stock wheels any more...
Old Dec 30, 2006 | 12:47 AM
METC240's Avatar
2005 C240 4Matic
Thanks for the tip... Already heading to that site...
Old Dec 30, 2006 | 12:48 AM
e1000's Avatar
a quarter mile at a time
You'll need at least 17"s to clear the 4 piston calipers and rotors from the sport sedans.
BTW, if you get crossed drilled rotors without getting a larger rotor, you will be more susceptible to warp your rotors.
Old Dec 30, 2006 | 12:52 AM
METC240's Avatar
2005 C240 4Matic
I have a 4 matic and appears that brembo will not work for my car
Old Dec 30, 2006 | 12:56 AM
vraa's Avatar
Few questions.
Are C32 brakes the same in the sport sedan?
I know that SL500 and C32 have same brakes, and I know evosport had a deal on them before. You could probably get them for less than 700$ today, I bet you could ask evosport for a groupbuy if a bunch of folks are interested.
It's an entire kit.
Old Dec 30, 2006 | 01:14 AM
METC240's Avatar
2005 C240 4Matic
I went with 18" non staggered since I have a 4 matic... Nothing to wild... I am worried on the inside of the rim may rub....
Old Dec 30, 2006 | 01:15 AM
METC240's Avatar
2005 C240 4Matic
"BTW, if you get crossed drilled rotors without getting a larger rotor, you will be more susceptible to warp your rotors."
sorry but I do not under stand this part. If i get cross drilled rotors I will have some warp?
Old Dec 30, 2006 | 01:20 AM
e1000's Avatar
If you get crossed drilled rotors that are the same size as the stock rotors that come on the 4-matic, the new cross drilled rotors will be easier to warp. This is because there is less material to absorb the heat generated under braking. Just something to consider.
Old Dec 30, 2006 | 01:25 AM
METC240's Avatar
2005 C240 4Matic
How can I avoid this then? up the size?
Old Dec 30, 2006 | 01:29 AM
DamonAnthony's Avatar
2003 Ford F350-gone 2002 Mercedes C200 Kompressor 1998 Suzuki Vitara 1995 Mercedes C180-sold
So its the sport sedan with the fancy brakes.....I think these look awsome!
Old Dec 30, 2006 | 01:32 AM
e1000's Avatar
yeah - the proper way to go crossed drilled would be to get a larger rotor, probably from a sport sedan would be easiest - but I really don't know if you can put them on a 4-matic or not.
I know that the 4-Piston brakes from the C32 are the same as SOME C230/320/350 sport sedans. You can tell by the calipers, they have 4 large screws on the outside instead of two.
Old Dec 30, 2006 | 02:04 AM
METC240's Avatar
2005 C240 4Matic
Is there a way to find out if I can get those on a 4 matic ? does anyone know ?
Old Dec 30, 2006 | 02:45 AM
I saw an S350 with what looked like the "sport" brakes but to be honest they didnt look as big as the AMG brakes, will have to find another one and have a better look!
Old Dec 30, 2006 | 08:11 AM
C24owner's Avatar
'08 E550 4Matic
I have cross drilled Brembos on my 4matic. I kept the stock size since I need to run 16" wheels in the winter; I havent had any problem with warping.
Old Dec 30, 2006 | 10:38 AM
wizkid's Avatar
Ford Pinto
This link may help you out some with information.
http://www.installuniversity.com/mb/.../amgbrake.html
Old Dec 31, 2006 | 12:04 AM
METC240's Avatar
2005 C240 4Matic
thanks for the site....
Old Dec 31, 2006 | 12:09 AM
METC240's Avatar
2005 C240 4Matic
Can I have the part numbers for the calipers and rotors? is there a place to look it up?
Old Dec 31, 2006 | 12:22 AM
wizkid's Avatar
Ford Pinto
Email "sunman" on this board. He did the install and has the notes, I just edited the photo's on that install and host the page.
I would guess he can also hook you up with a genuine MB set as well. Doesn't hurt to ask him. He has connections.
Eric
Old Dec 31, 2006 | 12:44 AM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
have you checked www.tirerack.com yet???
Old Dec 31, 2006 | 01:10 AM
rlee02135's Avatar
2004 C32 ///AMG
Carlab had a GB on Brembo x drilled rotors...
https://mbworld.org/forums/c-class-w203/170416-carlab-motorsports-brembo-replacement-rotors-gb-w203.html
depending on your budget, you should get OEM pads or Porterfields
Old Dec 31, 2006 | 01:16 AM
METC240's Avatar
2005 C240 4Matic
I did but they are to expensive. they only offer from what I found Brembo Big brake kits. I am Looking for a low cost, good look solution. I am now leaning toward the c32 upgrade if they work. I am going to take pic of my rims and see if it will allow for the upgrade.
For some reason I think they do not....
Old Dec 31, 2006 | 02:06 AM
rlee02135's Avatar
2004 C32 ///AMG
if they are 16's they will not, but then, you get bigger, better rims
