Chamber kits?
Old Dec 31, 2006 | 07:27 AM
Benzino's Avatar
03 c230
Chamber kits?
Do they make chamber kits for our rides? The reason i ask is, my car pulls to the right big time and my rear tire is wearking out like crazy because of this. I have lowering springs with one cut coil . does anyone have any ideas how to fix my alignment for my car even though i did it, and it did nothing
Old Dec 31, 2006 | 02:19 PM
sirenebekim's Avatar
why would you only cut one spring? Is the spring on the side that pulls?
Old Dec 31, 2006 | 02:21 PM
Benzino's Avatar
03 c230
come on now brother a coil on each spring
Old Dec 31, 2006 | 06:07 PM
is the camber on your rear tires leaning in towards the vehicle? I think thats an oem setup to create more traction... I just left it and will replace the tires as they wear out
I'm not clear on what exactly is going on with your car... You lowered it, I got that.. But cutting only one spring? I don't understand... did you cut off One revolution on each spring all around?
If you did cut, I would say thats not good. The spring will change as it gets warm and cold, so you can never really make the same distance cut on each strut unless you used an engineering formula and a micrometer
jmo
Old Dec 31, 2006 | 08:46 PM
Benzino's Avatar
03 c230
jmo
my car is cut one full spring and the tire is wearing out on the inside i think im not even sure i will check later
Old Dec 31, 2006 | 09:21 PM
jmo, but the independent suspension works on a triangular basis, that is, three points of contact, two with the road (either side of the tire) and one with the car.
By cutting the springs you made your triangle deformed by changing the sizes of the sides of the triangle. A2+B2=C2. Therefore, your two contact points on the tire are no longer flush with the surface of the road. Thats why you are wearing unevenly.
The springs that you cut, are they the OEM springs or aftermarket lowering springs? If you cut the OEM springs to the specs of the aftermarket lowering springs, you should be fine. However, if you cut the aftermarket springs even lower, you will no longer have the OEM sizes for each side of your contact triangle, therefore the triangle is no longer flush, or even with the surface of the road.
I hope this helps
Old Jan 1, 2007 | 01:43 PM
Benzino's Avatar
03 c230
damm im lost haha i cut h & r springs even lower .... so whats up does that mean im screwed? help me DR
I hope this helps
Old Jan 1, 2007 | 02:16 PM
im guessing that the HR springs lower the vehicle... By cutting those, you lowered it further than "allowed"
Somone mentioned something about camber adjusting lugs, maybe check that one out. Other than that I would say get new springs and dont cut them. If you want to go lower, get air ride? Then you can at least adjust the vehicle for when you encounter those steep spots in the city. I've seen lowered cars get stuck on those like a teeder tooder and it was funny as hell. I personally can't lower mine because in florida we have sink holes and i would scrape way too much for me... so what do i know about lowering lol
Old Jan 1, 2007 | 06:28 PM
Benzino's Avatar
03 c230
camber adjusting lugs? sounds like a beautiful thing tell me more! brother i really appreciate your responses thank you
Old Jan 1, 2007 | 08:41 PM
Benzino's Avatar
03 c230
i looked up the speedy benz camber arms.. so is that what i need? that will fix my problems? can anyone install it?
Old Jan 2, 2007 | 11:59 AM
do you have any pics of your setup? I would like to see a benz lowered, I personally love it I just can't do it.
as far as the camber kit goes, I'd say its worth a try if you have the extra money and really want it lower than what HR can provide. It should fix the "triangle". I don't know what they look like, nor have I ever heard of it. I tried to find Speedybenz website for the camber, nothing... I searched google and came up with nothing as well, other than forum logs.
What size wheels are you using? My 19x9.5 wear unevenly in the back, maybe the camber kit is what I need even though I'm not lowered. However, if my tires are even, it appears that the outer sidewall will rub the body. I could get the fender rolled, but I don't want to repaint my car. So I just leave it and replace the tires when they are due, which is about 40k miles or 1 year of driving for me.
Old Jan 2, 2007 | 12:05 PM
Benzino's Avatar
03 c230
im sorry i dont, but i do have a cam so hopefully sometime next week
Old Jan 2, 2007 | 07:14 PM
dnasty8305's Avatar
2003 c240
there is no problem with cutting a coil off your h&r springs...... just might be a little bouncier.......as far as your camber kit you can get one from the dealership or the speedy benz works well i heard.....
Old Jan 2, 2007 | 07:44 PM
Benzino's Avatar
03 c230
the dealership? interesting how much are they there? so will the camber arms fix my problem? if i got my car aligned will my car stop pulling to the right big time?
Old Jan 4, 2007 | 01:53 AM
Benzino's Avatar
03 c230
has anoyone heard of k- mac? any experiences?
Old Jan 4, 2007 | 12:17 PM
How about you heat up the coils and compress them too? That should get you another inch lower...
jmo
Old Jan 4, 2007 | 01:51 PM
fanito's Avatar
02' C230k Sport Coupe
my coupe also pulls to the right, not awfully bad but pulls enough for me to notice it. Is not lowered, I took it to check the alignment several times... (yearly alignment membership), tires are new (less than 2k miles) and check the air pressure to make sure are equal...still no clue why it pulls to the right
Old Jan 4, 2007 | 08:57 PM
Benzino's Avatar
03 c230
so anyone kmac? kmac or speedybenz i need these now! help
Old Jan 6, 2007 | 12:09 AM
TA-9FF's Avatar
One with 4 wheels
My 06 C230 sedan also pulls to the right. It did it when I first got it new last year, and my car STILL does it after I recently had the tires changed out and had the alignment done on it. I took it to 3 different MB dealerships to have it checked out and all of them kept insisiting the car is operating "under normal factory specs". Because of this alignment issue, my original OEM front passenger tire was looking pretty shredded at 16k miles, and the other 3 tires were looking pretty badly as well. I first assumed it was just the tires that were faulty (And I still attest to Michelin Pilot Primacy's sucking hard), but now I'm beginning to wonder if this is an even bigger issue....
It's shizznite like this that makes me consider trading it in for either Audi or BMW. None of my friends with those marques have this problem. If you search the forum, you'll come across a lot of "pulling to the right" issues.
Old Jan 6, 2007 | 02:19 AM
speedybenz's Avatar
AMG C43, 1999
I have the camber arms in stock and could send you a set this Monday.
They have been used on some 20 or so W203 and another 40 or so sets on various other MB models.
Cost is $260 which includes shipping. Paypal info: Kimdac@yahoo.com
The stock MB 5 link set-up allows for adjustment of the rear toe which will also need adjustment after you reset the camber to the correct settings.
Jeff
Old Jan 6, 2007 | 10:05 AM
dnasty8305's Avatar
2003 c240
the ones from the dealer are just the camber adjustment bolts wich work pretty good
Old Jan 6, 2007 | 12:57 PM
speedybenz's Avatar
AMG C43, 1999
Yes, the Camber, Castor bolts for the front work pretty good but will not work on the rear camber.
Jeff
