Another anti-sway\anti-roll bar thread...
Kleemann\Eibach: 24/22 - $475\$373
Evosports: 24/19 - $549
Brabus: ?\? - $625
AMG: ?\? - $300
RennTech: ?\? - $900
Carlsson: ?\? - ?
Lorinser: ?\? - ?
Thanks.
I love my C32 bars. They have a significant bias to rear stiffness (in other words, the front bar is a little stiffer than stock, the rear is a gigantic increase) and they work very well with stock, non-sport springs and shocks on my 2001 C240
The stats on the bars are:
C240 C32 % Change
Front 20mm 22mm 146.41
Rear 13mm 17mm 292.43
When considering new bars remember two things:
1. The stiffness of the bar increases with the FOURTH POWER of the diamter difference!!!!!
2. Keep an eye on the difference in front/rear stiffness bias of the new bar set compared to stock (as you can see above, the C32 bars have a strong bias to rear stiffness, which decreases understeer & increases oversteer).
. Hopefully, you can figure it out.I installed the bars myself. The front took about an hour, the rear was more like a half hour. Nothing too tricky.
Here are the part numbers (I found them faster than I thought I would!):
FRONT ASSEMBLY:
203-323-31-65 - Bar-front - $70.30
203-323-16-85 - Rubber mount (bushing) - $4.40 (2)
203-323-11-40 - Bracket - $11.50
203-323-12-40 - Bracket - $11.50
203-323-21-89 - Rod - $47.18 (2)
913023-012002 - Nut - $2.40 (4)
002-990-39-22 - Screw - $1.25 (4)
REAR ASSEMBLY:
203-326-00-81 - Rubber mount (bushing) - $7.60 (2)
203-326-15-65 - Bar-rear - $74.93
What else would need to be changed to make a C240 have the same suspension/handling characteristics as a C32?
I assume the C32 has a bias towards tighter handling, whereas my C240 has a bias towards a luxurious ride - is this correct?
That is why I have Eibach springs and Koni shocks on order for my C240.
I have a hunch that the suspension bushings in C32's are stiffer, but no evidence to prove it.
FYI: Our sale on the adjustable sway bars and underdrive pulleys ends this month. Both will be an additional $100 more in October.
Ben
If so, any feedback?
I'm still on the fence on this one; the extra adjustability would be nice, but don't know if I'd ever have a reason to adjust them (of course, you do get more starting points).
We are getting close to the time when Eibachs will be hitting our shores, though. Any thoughts?
Can you post a couple pics of the final product? TIA.
