Help!!!!!!!!!!!!!!!!!!!!
Old Jan 23, 2007 | 06:33 PM
bloodyhands's Avatar
2k1 c320, 2k5 wrangler, cbr 929
check engine sign came on after gas tank cap was closed improperly ... how do i get rid of it?
thanx for the help in advance.
Old Jan 23, 2007 | 06:38 PM
ultraman206's Avatar
M5
Just make sure you close it securely and the light will reset itself after a couple ignition cycles.
Old Jan 23, 2007 | 06:43 PM
TREZ63's Avatar
2010 RRS ; BMW K1200R; 14 E350 ; 14 RRS on order
+1, its part of the emission standards regulations, MB makes a big deal of it and flips the light. Just keep it off for a few days and you're set. I had the same issue a few years back.
Old Jan 23, 2007 | 06:54 PM
dam that was quick guys , thanx a million
Old Jan 23, 2007 | 09:46 PM
sirenebekim's Avatar
if it doesnt go away it could be a loose vacum line, or something else completely seperate, just bad timing... get the cheap ODB scanner from ebay and use the check code and reset function... anyone here ever use those?
