Help! Sub Wire Colors, Where to look...
Old Jan 24, 2007 | 06:36 PM
DougandhisC280's Avatar
2008 SLK-280
I have been searching this forum for literally 2 hours and could not find the answer to this question. I am trying to add a sub to my 03 C320 Sedan with the Bose sound system. I need to know what color the wires are going to the Bose Subwoofer to tap into them. I have removed every panel in the trunk trying to find where the wires are running to it but I still don't see them. Please help soon as my car isn't even drivable right now.
Old Jan 24, 2007 | 06:39 PM
gaogi's Avatar
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
The sub should be under the rear shelf. Go into your trunk and look up. There should be a subwoofer there. Assuming you're adding an amp too, you'll need to have a high/speaker level input on the amp, or get a hi/low input converter and just tap the signal wires going into the sub. Not sure if you can use the factory amp to power the new woofer, since I don't know what is the impedance on the Bose sub.
Old Jan 24, 2007 | 06:50 PM
2008 SLK-280
I see the sub. It faces down. I can't see or feel any wires going to it though.
Old Jan 24, 2007 | 07:08 PM
360_iti's Avatar
W203, W211, W219, W212
gaogi I just sent u a pm with questions. Thanks.
Old Jan 24, 2007 | 07:11 PM
C24owner's Avatar
'08 E550 4Matic
The wires are accessible through the top of the deck lid. You need to remove the thing that is circled, but on the other side.
Old Jan 24, 2007 | 07:20 PM
2008 SLK-280
That comes off without breaking it?
Old Jan 24, 2007 | 07:29 PM
C24owner's Avatar
'08 E550 4Matic
yeap. You need to pry it off. I use a plastic putty knife, but a regular flat-head screwdriver will work.
Old Jan 24, 2007 | 07:51 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
You can PM an admin and can have your name changed without being a noob again
Too bad you didn't request this wire color stuff 3 month ago. I deleted my 03 C320 files once I got my E.
Old Jan 24, 2007 | 07:56 PM
Cops_h8_me!'s Avatar
C63 AMG (stock right now), Beach Cruiser (debadged), Piper Cherokee 280 (too much to mention)
why delete?
With the price of storage drives now? you should be ashamed of yourself
Old Jan 24, 2007 | 07:58 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Why keep it when you moved on to bigger and better.
Old Jan 24, 2007 | 08:00 PM
HAHAHAH - to remind yourself of what you once were
Old Jan 24, 2007 | 09:03 PM
Belle the Benz's Avatar
2005 C320 -Sports package - black / black
I believe the wires are brown and brown with a pink stripe. They are bigger than the rest of the wires that go to the amp.
-----edit-----
whoops....I have an 05 with the H/K sound system, might be differant . sorry
Old Jan 25, 2007 | 09:48 AM
2008 SLK-280
I played with it some more last night. I tried to pry the plastic grill cover off. It almost broke so I gave up on that. If someone is absolutely sure that it just pops off, I will try it again. All the wires are hidden in the rear shelf. I'm usually really good with this stuff but this is just a pain.
