How many digits are Audio Security Codes
Also, I was searching and found a post on the W202 thread that stated that you had to hit the (SC) button after entering the code... is that the same for the stock cassette radios on W203?
Thanks. I haven't disconnected the battery yet, but I'd rather know now before I need to drive 500 miles in silence someday!
So if there is no code to enter, why are there stickers on the rear windows with a picture that appears to be a generic head unit that says..."ALARM CODE"
Strange?
The radio code on the W202 has only 5 digits. It's very simple to reenter the code. BTW, This is for a 1999 W202 radio. After the battery is reconnected, power up the radio. The radio will show 5 blank spaces. Enter the 5 digit radio code and hit enter. You're done. The radio will still remember your stations, preferences, etc. No need to reprogram. If you do need the code for some reason and you don't have the radio code card, just call up your dealer and ask them.
Dave
Tuner bands: FM 87.5 MHz - 108 MHz.
AM 531 kHz - 1620 kHz
LW 153 kHz - 282 kHz
SW 5800 kHz - 6250 kHz
Station Memory: 8 in FM, 4 in MW, LW and KW.
Frequency Response:
50 Hz - 20 kHz with CD Player
30 Hz - 15 kHz on FM
50 Hz - 2.5 kHz on AM, LW, SW
Autostore: FM, MW, LW.
Amplifier output: 4 x 15 Watt.
Loudspeaker Impedance: min. 4 Ohm.
Speed Dependant volume.
Antenna: Impedance 50 Ohm.
Telephone Mute: Low active signal < 2 Volt.
Power Supply: 12 Volt.
Soundsystem: Connection only for D2B Optical System.
CD Connection: Available for Mercedes-Benz D2B and Becker Silverstone 2662.
8 cm CD's with adapter is not recommended nor guaranteed playback with recordable CD's.
CANBUS enabled.
Theft protection is handled by a unit identifier signal over the CANBUS with the vehicle (the devices have no code). This identifier is checked at each operation of the unit. If this identifier is missing, then the radio goes into the PROD lockout mode and can no longer be operated.
The BE6021 is an update version of the BE4410. There are no operational or specification differences.
