Attention ASP Pulley Buyers
Old Sep 19, 2002 | 04:03 PM
20FHK02's Avatar
2002 C230 Coupe
When you receive the ASP pulley do NOT rush to put it on! You should inspect the finish carefully for any defects. I received my pulley today and I found a couple of burrs on the grooves. Make sure they are smoothed out otherwise they will cut through the belt!
Old Sep 19, 2002 | 04:39 PM
tb2's Avatar
tb2
2002 C230 Kompressor
Re: Attention ASP Pulley Buyers
How long is the wait now if one orders an ASP pulley? Still looking at over a month?
Old Sep 19, 2002 | 04:58 PM
20FHK02's Avatar
2002 C230 Coupe
I waited more than 5 weeks for mine.
Old Sep 19, 2002 | 05:37 PM
tb2's Avatar
tb2
Hmm, that's kind of a bummer, 5 weeks...
Old Sep 19, 2002 | 05:53 PM
20FHK02's Avatar
2002 C230 Coupe
I think they clamp at the groove when putting on the steel collar so the clamp claws make the burrs. For me this is forgivable for a $350 only investment
Old Sep 19, 2002 | 06:35 PM
firstkill's Avatar
20FHK02
are you gonna smoothen out the burrs your self? or send it back to be smoothened out?
firstkill
Old Sep 19, 2002 | 06:47 PM
20FHK02's Avatar
2002 C230 Coupe
I will deburr it myself. It's aluminum, so a fine file and/or sandpaper should take care of it easily.
Old Sep 19, 2002 | 09:13 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
You can use a scoring knife or even a flat screwdriver with sharp edges. The material is extremely soft and easy to work on.
Old Sep 19, 2002 | 10:04 PM
20FHK02's Avatar
2002 C230 Coupe
yep! It only took me 45 seconds to deburr
