AMG Airbox retro-fitting into a M112
Old Mar 1, 2007 | 11:08 PM
  #101
phattbam's Avatar
'08 BMW e92 335i
Originally Posted by advans
thanks, I thought you were selling the CF box!?
I couldn't do that. it looks so cool in there. I just need to find some green filter cleaner and oil.. Any stores sell them or would I need to order it online?
Old Mar 1, 2007 | 11:31 PM
  #102
advans's Avatar
C55 ///AMG, 535xi
I think you would need to buy it online! check greenfitlerusa.com, and maybe theres a store near bay area?
Old Mar 2, 2007 | 12:34 AM
  #103
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
did u DIY them?
Old Mar 2, 2007 | 07:29 AM
  #104
advans's Avatar
C55 ///AMG, 535xi
Originally Posted by Brabus_x2
did u DIY them?
yeap. most of the stuff I do is DIY!
i'm gonna hold off my "mod bugs" right now, and help my friend mod his 330xi. its gonna be mostly ACS!
Old Mar 4, 2007 | 02:32 AM
  #105
advans's Avatar
C55 ///AMG, 535xi
hmmm so no1 interested in this amg air box mod anymore!?
carlos did you do yours yet!?
Old Apr 6, 2007 | 12:04 AM
  #106
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Advans,
help....
the following parts do not come up on the EPC :
026367 A Driver's side tubing
026367 B Passenger side tubing
Can you identify those 2 parts on the schematic sketch below ????
Thanks !
Carlos
Saprissa@aol.com
Old Apr 6, 2007 | 12:12 AM
  #107
Saprissa's Avatar
Originally Posted by John Goodlad
...can you point out which air cleaner hose...
> A112 094 16 82
> A112 094 17 82
Carlos,
The parts #490 & #510 depicted in the EPC scan are indeed the US version (sedan) C32 parts. They measure ~2.125"X5.5" (~54mmX140mm) at their inlet ID. Part numbers are (thanks advans) A 112 094 17 82 and A 112 094 16 82, respectively. ~$12 each, MSRP.
They install over the ducts in the upper radiator/AC condenser filler panel, part number A 203 505 09 30. Since you're going to do this mod, (and I know you will!) you've no reason to use those scrawny tubes.
Trust we'll see 'em on at the next meet...
John,
Just got back from an assignment in Mexico, and will have some time to work on my C320 V6 3.2L Coupe.
...and the corresponding air hoses currently on the Coupe are part # A 203 528 01 07 (driver's side) & A 203 528 00 07 (passenger's side). Same as the C320 Sedan.
Which look very much like #490 & #510 in the schematic.
I ordered A 112 094 17/16 82 and will see how they fit.
Also, what is that part depicted as #440 ???? Do I need that ???
Carlos
Saprissa@aol.com
Old Apr 6, 2007 | 12:45 AM
  #108
advans's Avatar
C55 ///AMG, 535xi
Originally Posted by Saprissa
John,
Carlos
Saprissa@aol.com
part #440 looks like the stock paper filters.
btw, I have sold the AMG airbox. moving on to a new airbox project!
Old Apr 6, 2007 | 12:51 AM
  #109
Saprissa's Avatar
yes, but can you identify these 2 pieces on that schematic drawing ?
Old Apr 6, 2007 | 07:36 AM
  #110
advans's Avatar
C55 ///AMG, 535xi
its 490 and 510.
also carlos, at the Y section, (#460), the plastic clips that hold into the MAF, that doesnt fit our car.
either.... get the SL splitter while your at it and not get that one. or you'll have to clip it.
I suggest you get the SL splitter with these airboxes. it'll be sweet.
Old Apr 6, 2007 | 12:41 PM
  #111
Saprissa's Avatar
Question
its 490 and 510.
Thanks !
anyone got the PART # for the "SL splitter" and a pic of what it looks like ????
Old Apr 6, 2007 | 04:35 PM
  #112
advans's Avatar
C55 ///AMG, 535xi
Thanks !
shoot. I had that part#, I have no clue where it went. PM frank, I think he has a SL splitter.
Old Jun 23, 2007 | 05:46 PM
  #113
Saprissa's Avatar
Question plug
Gary,
what did you use to fill/plug that hole on the left side hose on the Y section ?
Old Jun 23, 2007 | 06:03 PM
  #114
Saprissa's Avatar
Gary,
one other thing. I haven't done this yet, because I was just running around with the 2 side tubes sticking out a little bit between the MAF and the air boxes. But I remember SUNMAN swapped the right & left tubes. These came attached to the Y Section. How did you remove the right & left side tubes, and more importantly, what did you use to glue them back on the opposite sides of the Y Section ??
I think the KLEEMANN adapter gives them more room, so they didn't sit too bad. But still I want to do it right this time around, that it will be permanent.
Dr. Sunil, if you're reading this, can you please chime in also.
Thanks !
Carlos
Saprissa@aol.com
Old Jun 24, 2007 | 12:34 AM
  #115
advans's Avatar
C55 ///AMG, 535xi
carlos, I plugged the holes with silicone. I'm not sure how sunil did it.
but my Y-section came "taken apart" and what I did was after switching sides, I sprayed silicone bond, and zip-tied it.
Old Jun 25, 2007 | 01:30 AM
  #116
Saprissa's Avatar
OK. Thanks.
I'm not too familiar with silicone, so I'll try to figure it out.
