Pirelli P3000, Kuhmo or Yokohama?
Admin Alumni
My Dunlop SP Sport A2s are worn out after just 21,000 miles, and I'm tired of tires without a treadwear warranty.
Thinking about the Pirelli P3000, or Kuhmo 716 Solus, or Kuhmo Ecsta SPT. The Pirelli has an 85,000 mile warranty, and the Solus has 50,000 miles. Don't know about the Ecsta SPTs. I've had some good luck with Pirellis, and I like the Kuhmos my wife has on her car.
Does anyone have experience with either of these tires?
Might consider Yokohama AVID V4S, too (60,000 mi). Other choices welcome.
My goal this time around is to find a 205/55-R16 or 225/50-R16 tire with at least 50,000 mile tread warranty (Actually I don't care about the warranty as much as a design capable of it.) Quiet tire is a need too, along with good wet weather traction.
I'm not buying new wheels so spare me the advice on 18s and 19s, please.
Mercedes-Benz
Bob, why are you getting V rated tires? If you drive on the highway and want a quiet ride you should be looking at H-rated... thats what came on my C-class. the Avid H4S is an alright tire... I would stay far far away from pirelli if u want a quiet tire. Michelin has the quietest tires that I have found.
1993 Cutlass Ciera SL w/ 3300 Buick Engine
pirelli has a great compound (they do stick to the ground) excellent handling but TOO soft ...
if money is no objection, go for the Yokohama ones
Kumos will not get you 85K miles that is for sure. I have them on my 19s and they have a treadwear rating of 320 which I think I would be lucky to get a third of the way to 85K.
I have a set of Bridgestone Potenza RE960AS Pole Position's going on the C230 this weekend. I have worn the Conti Extreme Contacts out![BeatDeatHorse](https://mbworld.org/forums/images/smilies/beatdeadhorse5.gif)
I'll let you know how they do. Check out the TireRack ratings in the mean time.
Admin Alumni
So, I think it's down to two choices...
Yokohama YK520 (92H) or the Kuhmo 716 Solus (92H).
The Kuhmos are $60-$70 cheaper than the Yokos, and the salesman at Discount tire says they are basically equivalent in ride, noise and treadwear.
the Pirelli 3000s are T speed rated, so they are out, and you're right Kar don, I don't need V speed rated tires...
Opinions?
Opinions?
A box on 4 wheels
I have Kuhmo Ecsta SPT, compared with my last set of tires that were Pirelli Pzero Nero, Kuhmos were more quiet and they did overall pretty well in wet road conditions.
1 Post
2005 C230 Sedan 6spd
Just put on PZero Nero M+S 2 weeks ago, It's a little handling trade off compared to my previous Pilot Sports. The car rides more smoothly now, and it has treadwear rating of 400. Maybe something you want to consider. Pirelli's are great tires. If I were you I go with Yokohama AVID
2005 c230k
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
I recommend these tires for the original poster that stated this thread.
2001 C320 (purple), 2002 BMW 540i
General Exclaim UHP from discount tire for $83. Seriously, they're awesome tires- just look them up on tire rack. At $83, you can afford to try them out. If you still don't believe, you can try mine out
I got the best tires I've had in a long time on both our SLK230 and C230, Riken Raptors, under $400 installed out the door for all four on the SLK (17" C7 wheels) and slightly higher on the C230 (staggered 17" wheels). They are much quieter than any tire I've tried so far including the factory michelin, factory conti's, bridgestone pontenza re750 and pirelli pzero nero. Also, they have a rim protector bead, looks decent and doesn't have the stigma of korean kuhmo tires. Don't know how long they last but they have a decent wear rating.
I too was tired of rapid wear of performance tires on my daily driver Porsche. The motorsport shop I use suggested Yoko's. In my charge up the 5 past downtown LA at an average 40 mph, 70 tops, I cannot tell the difference. They were not the cheapest tire on the rack, but I think they are much more economical than the V rated tires because of the triple or quadruple treadwear. The motorsport shop insists that the tires are filled with nitrogen for longer life, and has given me a small steel cylinder for the house to top off. I find that I don't need to add nitrogen as often as I did with air. The rims also stay clean inside as corrosion is almost eliminated.
Try the Yoko's MB-Bob, and get some green valve stems, you'll do fine.
2003 C230
Put on Yokos H4S on last week
Best mod I can think of. Ride got quieter, better grip in winter conditions. Of course, being H-rated they get squirmy at the limit but they are the best highway tires I've ever had.
Admin Alumni
Bing, how old are those Consumer Reports ratings? I've not been able to find pricing anywhere close to the prices in the table, leading me to think the table is pretty old.
Well, the Yohohama YK520s are on the car. They look nice and ride nice and quiet. $107 a tire plus $11 mounting, with all the add-ons that Discount Tire demands.
1 Post
C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
this one is
November 2006
![](http://img513.imageshack.us/img513/4275/tires2007ho8.jpg)
Tires Seasoned Performers
LIFE ON THE ROAD Our demanding tread-wear tests again demonstrate that a manufacturer’s warranty doesn’t always reflect how a tire will wear. Until recently, performance tires were fitted mostly on sporty or luxury vehicles. Now they come standard on many everyday sedans, such as the Toyota Camry, and on some trim lines of economy cars, such as the Kia Rio.
Indeed, performance tires currently account for 21 percent of the replacement tire market and are often the best choice for more performance-oriented late-model cars.
The trade-off for higher levels of handling and grip achieved by performance tires, however, has often been tread life.
We reintroduced tread wear to our tire-testing program last year. This year, we made our test more demanding by extending it from 7,200 miles to 16,000 miles, including more driving on city-type roads. We found that wear varied from model to model and did not necessarily follow tread-wear warranties.
This year’s tread-wear testing took place over more miles than the testing that manufacturers use to assign their tread-wear grades. As a result, we believe our Ratings show better differentiation than the tread-wear rating you’ll find on a tire’s sidewall or the manufacturers’ warranties.
We tested 35 performance all-season tires, which provide balanced handling and braking in dry and wet conditions and provide nominal performance in snow and ice conditions. We also tested 20 performance winter tires, which are good in regions where drivers must drive over snow and ice in colder months.
Performance All-season
Performance all-season tires have a higher speed rating than standard all-season tires (see Types, available to subscribers). They generally provide better handling and braking, and usually have a lower profile (shorter sidewall height) and a wider footprint.
Performance all-season tires, as we define them, come in two speed ratings:
H-rated (130 mph). The most common performance all-season tires on the market are designed to handle and grip better on wet and dry roads than conventional tires, without giving up much in ride comfort.
We found some substantial differences among the H-rated all-season tires we tested. Most were very good or excellent in our tests of braking and handling on both dry and wet pavement. And most were good to excellent at resisting the tendency to hydroplane, or lose grip, when they hit standing water. Almost half of them were competent at coping with snow and ice, comparable to good conventional all-season tires.
We tested 22 sets in a common 15-inch size, P195/65R15. For any given tire in our Ratings, we expect performance to be comparable in a range of sizes.
V-rated (149 mph). Generally, these tires are more tuned to performance than H-rated all-season tires. Here, too, we found some significant differences between the V-rated tire models in our tests. Some V-rated tires sacrificed winter grip for superior cleared-road handling and grip. Other V-rated tires behaved more like H-rated tires, with good all-season qualities but less ultimate grip than the more performance-oriented models.
The 13 V-rated tires we tested were wider and had a lower profile than the H size. We tested them in a common P205/55R16 size.
