How to rewire pre '05 taillights to light up like the '05
Old Feb 14, 2007 | 11:31 PM
GPI's Avatar
GPI
W203 (sold), W204 (sold), W124
How to rewire the taillights so that they light up like the '05s? The tails of the pre '05 W203s only light up 3/4 of the way while the '05 light up all the way.
Anyone knows how to do it?
Old Feb 14, 2007 | 11:58 PM
e1000's Avatar
a quarter mile at a time
the tail light housings are different
Old Feb 15, 2007 | 12:23 AM
benzmodz's Avatar
W203 slightly modified
After doing the upgrade myself I decided that it was better to use the factory wiring harness that goes with the lamps.
Even then the bottom red runnings lights were not both lit. What needed to happen was that there was some coding that only Steve or Sunman can do that will illuminate both of the bottom red running lamps on the rear.
Overall I am satisfied with the results.
Old Feb 15, 2007 | 02:45 AM
GPI's Avatar
GPI
Do you know how to remove the taillights? Any instructions?
Old Feb 15, 2007 | 06:25 AM
benzmodz's Avatar
Take off the screws and it falls out. Perhaps remove the whole trunk interior first.
Old Feb 15, 2007 | 09:55 AM
///AMG4EVER's Avatar
CLS55 Designo 030
Hey benzmodz, can you give me more input on this mod? I really want to do this... Is it possible to see a picture of your results? Thanks.
Old Feb 15, 2007 | 11:38 AM
GPI's Avatar
GPI
Yeah. Pics would be great.
Old Feb 15, 2007 | 11:57 AM
coin's Avatar
'06 CLK500
hmmmm... should be a nice mods for the car if it's an easy DIY
Old Feb 15, 2007 | 02:55 PM
benzmodz's Avatar
Diagnostic coding is not DIY. Parts are easily ordered from MBENZNL and you have to ask for the cable cable harness and ties.
Old Feb 15, 2007 | 05:52 PM
rlee02135's Avatar
2004 C32 ///AMG
its very easy if you have the S-Tails...
Old Feb 15, 2007 | 06:51 PM
Ryanr317's Avatar
R129, XF Sportbrake, SC400
Care to share? Mine are on their way so i'll be needing to know. I didn't stff but if it's been discussed many times just let me know.
Old Feb 15, 2007 | 06:58 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
https://mbworld.org/forums/showthrea...***+taillights
Old Feb 15, 2007 | 07:03 PM
rlee02135's Avatar
2004 C32 ///AMG
basically reveal wire from the current light and rear fog..then tape them together.
Old Feb 18, 2007 | 06:24 PM
C24owner's Avatar
'08 E550 4Matic
I tried doing this today and got it to work. The only problem I had was that the Left license plate light would flash. At first I thought that it was the bulb, but I undid the connection for the tails and it stopped flashing. Anyone know what the problem is?
Old Feb 18, 2007 | 09:26 PM
benzmodz's Avatar
It is not wired properly and the car is more intelligent than people give it credit for.
Old Feb 18, 2007 | 10:21 PM
C24owner's Avatar
'08 E550 4Matic
I thought that I wired it properly. All I did was tap into the power from the bottom running light. It worked fine.
I just dont know why that would cause the left license plate light bulb to flash. And why would only the left one flash and not the right?
Old Feb 18, 2007 | 10:46 PM
benzmodz's Avatar
You doubled the current and the resistance. Then the rear SAM goes postal thinking there is some kind of serious problem and starts to flash another lamp to check if it is broken.
The way the rear SAM checks the lamp is to flash them and records the difference in current and resistance. Finding a cheap way to hack the car does not mean you did it properly.
Doing it properly means you used all the correct Mercedes parts.
Old Feb 18, 2007 | 10:51 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
ain't that the truth !!!
Old Feb 19, 2007 | 07:35 AM
C24owner's Avatar
'08 E550 4Matic
Ahh. okay that makes sense. I knew it couldn't of been that easy.
Old Feb 19, 2007 | 06:57 PM
GPI's Avatar
GPI
So what are you suppose to do?
