my dc power outlet is not working
Old Feb 23, 2007 | 03:38 AM
2468024680's Avatar
hi, I have a 2002 230k, like few days before, I tried to use the 400 watt vacuum in my car, I used it with a converter. after I turn on the engine, the cigarette lighter type power outlet is not working. I used my cell phone to test it. I don't know what to do with it. do you guys think I should take my car to some autobody shop? or someone can tell me how to fix it ?
thanks
Old Feb 23, 2007 | 03:43 AM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
400watt is waaaay too much to handle... even u use a converter, it pull too much from ur car battery, check ur converter if it support 400watt+ and even it is i think is fooked...
Old Feb 23, 2007 | 04:45 AM
2468024680's Avatar
it supports with 400w but no matter I use it or not, the power outlet is not working, thanks for your opinion
Old Feb 23, 2007 | 09:16 AM
C24owner's Avatar
'08 E550 4Matic
Did you check to see if you blew a fuse?
Old Feb 23, 2007 | 09:46 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
Should be fuse #47 I believe in the fuse box under the hood next to the brake reservoir. It a blue 15amp fuse.
Old Feb 23, 2007 | 10:53 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Talking
yeah, autobody shop should work...
some BONDO takes care of everything !
Old Feb 23, 2007 | 11:02 AM
rlee02135's Avatar
2004 C32 ///AMG
LOL
Old Feb 23, 2007 | 11:37 AM
andrewplanet's Avatar
'01 C240
15amp fuse = 180 watts max. 400W would definitely blow that fuse immediately.
Old Feb 23, 2007 | 01:03 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Uh...no. You are incorrect sir.
Basic Electrical Theory-
Ohms law- Watts= Voltage X Current
So, 400/12= 33.3 Amps.
More than twice the capacity of the cig lighter circuit.
Just put in a 40 amp fuse. That should fix it.
Doh!!!
Old Feb 23, 2007 | 01:26 PM
Ok, after considering the consequences, I decided to inform you to definitely not use a 40 amp fuse. Here's an online calc for you.
http://ourworld.compuserve.com/homep...en/ohmslaw.htm
It's somewhat customary to have a little fun with the newbies here.
So, if you still think it should work, put in a 120A fuse, connect everything you can, and post photo's before and after. Video would be even better.
It's fun to watch stuff blow up.
