THUMP/BUMP when stopping ?
me really softly ??
It's really noticeable and happens at almost every stop ???
Any ideas ?
Thanks,
John
I dunno what you mean w/ "play in the tranny" ....
1 ) Warped rotors...when you have warped rotors (Forgive me if you already know this...just want to make it clear if you don't) the surface of your brakes' rotors are uneven...so when you brake (applying pressure on the brake pads onto the rotors) the brake pads will "read" the surface of the rotors...which will be an uneven surface with possibly a lot of bumps...so pretty much the brake pads are going up and down some bumps on your uneven/warped rotors.
2) I forget where I read this...somewhere on this forum, but I heard it's something to do with the fuel lines (or something to do with the fuel). It wasn't brought up too long ago...I'm sure you can find it...but I think their interpretation was that when the guy braked, the fuel would slush at a certain location in the car and that would cause the sound/bump you feel...But again, I'm not exactly sure...but it should be somewhere on the forum.
Good luck with whatever it is...Recently it happened to me....but that's the only time I recall that ever happening...and this was about a week ago.
Fluid & filter change might improve it. You can catch all of these cars doing it now & again through clumsy driving. Yours is obviously worse. You can also catch out the Torque converter lockup clutch by clumsy driving.
