needing new tires after 18,000 miles?
Old Mar 9, 2007 | 10:07 AM
henry47's Avatar
asdf
I purchased a brand new 2005 C230 and after 18,000 miles I've noticed that all four tires are bald. I'm PRETTY sure tires are supposed to last longer than 18,000 miles, especially this car hasn't been driven hard at all. Is this an issue I can take up with mercedes? or am i SOL? BTW, the car is entirely stock.
Old Mar 9, 2007 | 10:09 AM
outaurleague's Avatar
w211 e500
May need an alignment. Or they were really crappy tires.
Old Mar 9, 2007 | 10:12 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Yeah, check for uneven wear. If none, then you got stuck with crappy tires (probably Continental).
18k isn't really that bad. Proving anything on a wear item would be next to impossible.
Old Mar 9, 2007 | 10:20 AM
henry47's Avatar
asdf
is this issue not covered by mercedes warranty? if i'm not mistaken, BMW covers uneven worn tires and replaces them.
Old Mar 9, 2007 | 10:23 AM
BIGjohnny's Avatar
/////AMG
I find it a little strange that all four tires at 18k need a replacement. Since the car is a RWD, the front should last a lot longer unless it's lowered. But 18k miles isn't so bad, i wouldn't be complaining.
Mercedes won't do anything. The tires that comes equipped does not guaranteed any mileage. They only replace any defected tires i.e. blown tires.
Old Mar 9, 2007 | 10:24 AM
w211 e500
Not sure, i just renewed mine, i will read it when i go to lunch to see. Best to call your stealership - But you may not get the answer you want. I'll still check later today for you.
Old Mar 9, 2007 | 10:25 AM
w211 e500
2nd.
Old Mar 9, 2007 | 11:34 AM
flush's Avatar
2003 C32
18k?
My tires (michelin pilot a/s) were gone after .... 10-11k, especially the rear ones (right) - replaced the front as well. if you can't rotate your tires (or didn't)...
Old Mar 9, 2007 | 11:39 AM
w211 e500
Originally Posted by flush
18k?
Yeah staggered = no more rotations for me "SUCKS" - But im about to start scouting some reall good winter tires here soon.
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
OEM tires on my 05 were Pilot Sports, the front still had about 20% left when I replaced it at 50k miles, and rears were bald at 30K. I drive moderately aggressive, I would suggest you get alignment check too. 18K thread life is below average in my opinion. I mean 23K~25K miles should be about right.
Old Mar 9, 2007 | 12:04 PM
Cloudz's Avatar
2007 C280 Avantgarde
by the way guys, I am wondering, how many miles/km until tire rotation?
Old Mar 9, 2007 | 12:14 PM
Buellwinkle's Avatar
You can not rotate tires on the sport sedans, the fronts and rears are different sizes and you can't rotate side to side because the tires are directional. Just get better longer life tires next time. I got Riken Raptors, they've been great and are very cheap, a little over $420 out the door for all four.
Old Mar 9, 2007 | 03:07 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
+1
Old Mar 10, 2007 | 01:51 AM
c230K415's Avatar
AMG GTS
I got the same problem you do...my tires from the factory balded a lot...well not exactly balded but you can really tell they wore down really quickly compared to any other tires on my friends' cars...I have the Michelin's that came wit hthe car from the factory...can't name the size and model off the top of my head but all 4 wear evenly just that they wear quickly...
In fact...tonight I was taking my girlfriend to this nifty spot...and there's a couple of tight turns (180 degree turns, hairpins, etc) and when I was at 10 MPH hitting this one hairpin my tires spun out....I barely noticed (which is pretty cool because that tells me the ESP does its job i guess) but thing is...10 MPH...and it looks like a turn I could have taken 25 MPH in my SUV...so I guess I am due for changing tires
Old Mar 10, 2007 | 02:14 PM
blueserenity777's Avatar
Nov 04 W203
UK cars came with Continental Sport Contact 2..They did last me about 25K but were very noisy..Now I have the Michelin Pilot Sport 2's and they are simply remarkable..Low noise and fantastic grip..and the treads look nice..Just hoping the michelins last..Fronts are 225 while rears are 255..
All depends also on style of driving..and type of roads..
