trunk light
Old Sep 27, 2002 | 02:12 PM
antonio's Avatar
2002 C240 Classic
trunk light
does anyone know how to remove the plastic housing in the trunk so i can change the bulb. i've tried prying the plastic of with a screwdriver, but it just won't come off. anyone know how i can get at the bulb? thanks.
Old Sep 27, 2002 | 02:29 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
it would help to know the car and wchich light. either the LEb brakes of the side brake lights.
Old Sep 27, 2002 | 02:53 PM
PoonerElRay's Avatar
2017 GLA 250 4Matic
I think he's referring to the Coupe's trunck light. The dinky light that turns on and lights up the inside of the trunk when you pop it open.
Old Sep 27, 2002 | 03:02 PM
antonio's Avatar
2002 C240 Classic
sorry guys, i have a 2002 c240 classic, and i'm referring to the trunk light located on the top. hope that helps. thanks.
Old Sep 27, 2002 | 07:42 PM
mleskovar's Avatar
'17 Jaguar XF
I have the same problem...C320. I tried prying it straight off but no luck. What's with the light bulbs on these cars? They are constantly going out. The error code for "replacement bulb" constantly comes and goes as well. A front blinker stopped working and they have to order an
entire assembly to fix it! Here's what somebody told me is in a service bulletin:
Turn signal update/modification to l/f and r/f turn signal bulb socket wiring harness.
1 203-826-02-82 SPOM ONLY
1 000-545-78-80 PLUG
Old Sep 29, 2002 | 04:15 AM
xc240x's Avatar
2001 C240
well guys i have a 2001 sedan... and on one side of the trunk light, there's a little slot... you have to insert a small flat head screwdriver on each end of that slot... there are two clips that you have to push in... then pull the assembly down... you'll need two small screwdrivers so you can push the clips in at once, and your other hand can pull the assembly down... here are some pics (on one of the pics i'm pointing at one of the tiny clips that have to be pushed... hope all this helps!!!
Old Sep 29, 2002 | 04:22 AM
xc240x's Avatar
2001 C240
pic number two
Old Sep 22, 2008 | 11:56 PM
mbpc320's Avatar
2002 C320
Does anyone have pictures of this? I've been prying away and I can't get the housing to come out. I have a 2002 C320. I looked at the first six pages of a search run on "trunk light" and this was the only thread that dealt with the actual issue. Thanks for your help.
Old Dec 28, 2010 | 05:08 PM
fosterengraving's Avatar
2001 mercedes benz c320
thanx
Old Jan 27, 2019 | 08:13 PM
JasonMB's Avatar
c230k
Here are some pics of the trunk light from my 2003 c230k sedan for those that are are struggling to remove theirs. I resorted to moderate brute force... sucky thing is that there is no voltage at the connector and the bulb is fine. Is there a fuse number for this and where is the actuator for the light?
Old Feb 3, 2019 | 01:11 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Mine has been burned out for a number of years. At least now, I see how it comes out. Worst cas scenario, I now have the part number for a new one!
Old Feb 5, 2019 | 03:57 PM
JasonMB's Avatar
c230k
it is just a standard barrel shaped bulb that is easy enough to replace... once you know how to remove it! But my money is on this being a common issue with the bulb being fine but it not getting power.
Old May 11, 2020 | 12:47 AM
mercedes240's Avatar
C240
Question
i have same issues, if you find out solution to fix please help share
