C32 brakes horror finally over?
#51
2005 C55, 1988 260E, 2000 Chevrolet Silverado
When I improved my brakes I was told it was a waist of money and that it didn't make a difference anyway. As long as you have enough to lock them up you didn't need bigger brakes. LOL, I didn't even bother arguing. I've spent time on the track and back roads with the Porsche and I know what I need to feel confident and in controll. I have had the c32 brakes fade a little coming off of the pass at speed. but was not a big issue. I had some space to work with. But on the track it could be a different story. I'm going for the advanced driver coarse soon so I can go to more track events. And I might take the Mercedes to work on driving skills with it. So this might be something I have to do. I'm glad someone gets it, and the car looks great.
#52
Former Vendor of MBWorld
some slow@$$diesels
after having driven 3000km through germany during the last 5 days I am extremely impressed with the brake improvement - the car finally slows down bigtime and without complaining about fading issues due to some heat.
I should have done this a long time ago...no more worries about being cut off when doing 200+ kmh speeds.
greetingz,
greetingz,
#57
1 Post
2002 C230 Coupe(M111)
Fastest places in the states? Chicago tollways on weekends...never ever a cop, and everyone running ~100mph.
#60
2003 C-Class Sportcoupe
SLK55 [030]/CLK63 brakes are the same...and SLK55/latemodel CLK55 brakes are the same as well
The SLK brakes are not made by Brembo so the rotos are not available from Brembo either...DC used a different manufacturer for the SLK brakes (as far as I have been told).
SLK55 & SLK55 [030] rear brakes:
003 420 30 83 - calliper R: 327.92
003 420 29 83 - calliper L: 327.92
004 420 49 20 - brakepads: 99.14
171 423 02 12 - rotor: 116.88 each
SLK55 front brakes:
003 420 48 83 - calliper R: 415.36
003 420 47 83 - calliper L: 415.36
004 420 50 20 - brakepads: 98.38
171 421 01 12 - rotor: 439.55 each
SLK55 [030] front brakes:
003 420 68 83 - calliper R: 415.36
003 420 67 83 - calliper L: 415.36
209 421 01 12 - rotor: 513.96 each
the metal dustcover plate behind the brakes probably has to be changed as well...ALL PRICING IN EURO
greetingz,
SLK55 front brakes:
greetingz,
#62
Wow.
I never felt like C32 brakes were Ghetto...till just now.
Wow.
#63
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
will CLK55 REAR AMG brake set up work on 17"
Here's the parts list I got, however, I was told that the REAR CLK55 AMG brake set up would work on 17" rear wheels. Steve is this true ???
Rear Caliper AMG - left 003-420-29-83
Rear Caliper AMG - right 003-420-30-83
Rotor (x2) - 171-423-02-12
Protective Plate - left 171-423-01-20
Protective Plate - right 171-423-02-20
plus a few miscellaneous screws, thrust pin, dust caps, bleeder valves, & pins.
Carlos
Saprissa@aol.com
#64
2007 C350 SS
AMG Rear Brakes
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
#65
MBworld Guru
white and whiter
AMG Rear Brakes
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
#69
Something Slow
Saprissa... everything thats in the picture is what i will need for the CLK55 Rear to install on my C320 with out any problems??
#72
unless you want to cut them yourself, as Steve suggested above.
Originally Posted by rlee02135
yep, except you will need to cut your rear heat shield.
how much cutting do you have to do to the heat shield ?
You are referring to the heat shields for the exhaust muffler, correct ?
Do you have any pics of that ?
Carlos
Saprissa@aol.com
#73
2004 C32 ///AMG
you have to cut off enough to clear the caliper, but I just cut the whole thing off because for some reason, my rotors were touching the shield.
#74
EVE
You're cutting a section (almost a 1/4 of the shield sometimes) that's completely vertical. The rotors touching the shield? Just bend them back until they don't.
