C32 brakes horror finally over?
Former Vendor of MBWorld
some slow@$$diesels
after having ruined 2 sets of C32 front brake rotors and 3 sets of C32 front brake pads (in approx 40.000km - 25.000 miles) I "finally" moved up a step.
I honestly do not understand how these C32 brakes ended up on the C32, C30CDI, C55 and early CLK55s as those suck like crazy!!!
Usually when cruising the german higway at 200-230kmh (125-140mph) the C32 brakes allowed me to slow down to 90-100kmh (60mph) three or four times in a row before they would not slow down the car at all anymore - what a POS brakes.
So, all (front and rear) C32 brakes have been removed in order to make place for a set of SLK55 [030] front & rear brakes (same as on the CLK63). The front [030] brakes are slightly larger in diameter then the non [030] SLK 55 front brakes (same as on the later CLK55).
Now I just need to find a set of 18incg wintertires for next year's winter...
![](https://img124.imageshack.us/img124/8763/dsc00295sv0.jpg)
![](https://img411.imageshack.us/img411/50/dsc00297he8.jpg)
6 piston front calipers with 360mm multipiece rotors
![](https://img256.imageshack.us/img256/5213/dsc00298cy2.jpg)
4 piston rear calipers with 330mm rotors
greetingz,
greetingz,
some slow@$$diesels
yes - straight bolt-on...only modification that is required is that all steel dustcovers behind the discs have to be trimmed (I bought 4 original dustcovers just to discover that those were the same BUT with some corners CUT-OFF which made cutting off my own existing dustcovers just as easy).
pricing of a set of new SLK55 [030]/CLK63 front & rear brakes:4650USD excl. shipping
pricing of a set of new SLK55/CLK55 front & rear brakes: 4400USD excl. shipping
greetingz,
greetingz,
2004 C32 ///AMG
greetingz,
greetingz,
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
should've bought that complete set on ebay for $1200
why so expensive? Brembo GT BBK is way less.
1 Post
03' E39 M5, 10' CLS63 AMG
dam those do look nice, i'm looking into getting CLK63 brakes and the cheapest i can fit it is $7000 for the whole set which is a little too much for me. so i have been trying to save up but its going to be tough to cough out 7000g's
1 Post
u got the brakes of a CLK 55 i want it off the CLK 63 and i have come to realize that the CLK63 has different brakes. the brake calipers are different from CLK55 to CLK63. so how much would it cost if u were to get me the CLK63 brakes
Looks amazing. What is the ballpark on shipping and how difficult is it to modify the dustcovers?
2005 C55, 1988 260E, 2000 Chevrolet Silverado
I have the rears but stayed with the C32 fronts because of the snow tire issue. Now Tire Rack has some nice snow tires in 18's finally. I might upgrade the fronts now. Maybe its how your wheel is sitting but are the rears drilled and slotted like the fronts? Mine have the slots on the rear rotors.
MBworld Guru
white and whiter
looks awesome Steve. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
problem with the C32/55 brakes is that the rotor's heavy and the pads suck which will glaze the rotor after few heavy stopping. I think changing the pads help.
POS brakes that came with my coupe.
I don't get to drive that fast in the US anyway, or if I do, it's a quick run, and back to "normal" ie slow, 65 Mph. It takes a lot for me to get any fade, but I am running the Akebono ceramic, which can fade after a while.
Still most of the time it's not a problem in the US.
Anything more can cost your license, and they impound your car at like over 100.
Yeh, Europe, it might be different.
Certainly Portfields might fix that.
Of course the C32 brakes come with one rotor that turns the wrong frickin' direction. Dummass maneuver by MBZ.
BTW, thats one HOT smokin' wagon.
MBworld Guru
white and whiter
The C32 brakes are still highly superior to the stock single piston
some slow@$$diesels
the brakes that I installed are the SLK55 [030] brakes which are the same as the CLK63 brakes (and that will cost 4650USD excl. shipping)...the ones you think that I installed but didn't install are the regular SLK55 brakes which are the same as the CLK55 brakes and those cost 4400USD excl. shipping...so the brakes that I did install ARE the ones you want to have as well and you got quoted 7000USD for...
greetingz,
2007 C280 Avantgarde
Getting from my house to the university of BC takes an hour in the morning, 30 minutes of that = idle time.
Highest speed during ride = 65 mph (around then +5/-5 depending on traffic/cops/rush)
Average Speed = 30 mph
So no, I don't even see a point buying a C55 here in BC... there are traffic lights every block, stops you every two minutes, and you wait for two minutes until it changes, you slam the gas, and stop in front of the next light for another 2 minutes. So no, we dont usually slam the gas up here.
(NOTE - if you are stopped at 1 light, you will stop at all the subsequent lights)
So no AMG brakes needed for us here
2003 C-Class Sportcoupe
Steve, I'm glad you finally got rid of those C32 brakes. Can you tell me the part # for the rear rotors from the SLK55 030 kit? I need rear rotors so I can install my rear 4pot Alcon/Brabus calipers. The rear alcon calipers use 330mm x 21mm rotors.
1 Post
did you read what I wrote up here?
greetingz,
greetingz,
i got the quote as 7000CAD but either way ur price is better, did u have any problems installing ur brakes?
what is included in the package of 4650.00USD
1 L front caliper
1 R front caliper
2 Front Rotors
1 L rear caliper
1 R rear calper
2 rear rotors
2 front brake pads,
2 rear brake pads?
is there anything i need?
some slow@$$diesels
so do these
4 rotors, 4 callipers, front & rear brakepads & front wear indicator (rear is same, front is different)
something useful/more suited in the snow
greetingz,
Originally Posted by Blake P
What kind of tires do you use in the winter, all-season or something more suited to snow and ice?
greetingz,
