fuel filter/pressure reg C240
I'm at 66k miles.
Ps. How do I know if I purchased the correct one for my car?
but it's worth mentioning for those who want the 335i Coupe/Sedan...
I have a couple of friends who have this problem with the new 335i Sedan/Coupe... it doesnt affect all vehicles, but it is an annoying problem. ifyou are planning to buy one of these... just beware
.....UPDATE: Car failed to start on friday afternoon ! Ugh. Towed it to a local shop, Crank Sensor failed! I was wrong about it being the fuel filter. Sorry guy's. Carquest got a sensor from world-pac. I should get the car back to- day. $390 bucks. Diag, plus 1.8 install labor and the sensor ($about 150.00)
It's located at the back of the engine, near the trans bell housing. According to a tech bulletin, moisture can get in the connection causing corossion and failure. Symptoms are rough running, hesitation, and crank no start conditions. A " re-initialization " procedure has to be performed to make the new sensor work, so I recommend a shop or the dealer if you loose your sensor. Looks like it affects 2001 C, E, and S class cars. v6 and v8. Thats all I know. =)
