Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Rating: Thread Rating: 64 votes, 5.00 average.
Old 08-02-2004, 09:30 AM
  #576
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
Originally Posted by x-tian-230k
If you want u should buy the 05 projecter clear lens halogen headlight assemblies...i think i saw them for like 500 dolalrs on ebay...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
Old 08-02-2004, 12:41 PM
  #577
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my advice is, save your $$$ and get the BIX. you wont regret it.
Old 08-02-2004, 04:21 PM
  #578
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Exclamation
Originally Posted by Kev04C320
Try contact Steve, the Euro parts pimp, you might be surprised how much those lights cost.
About 2 weeks ago, Steve only had ONE pair of Bi-Xenons left for the COUPE. Price was $1150, however, it had minor rock chips.
I'm looking for an original Bi-Xenon set for the COUPE, and don't know who else might sell these at a good price. The ones on eBay are usually chipped as well, and sometimes do not come with all the right plugs and things.
Remember, Bi-Xenon headlamps are different sizes for the Sedan & Coupe.
Old 08-02-2004, 06:56 PM
  #579
LaZyC230K's Avatar
thanks very much on all your advices, it really helped me get thru what i wanted, i think im going to get the 05 xenon assemblies. one more question, does the bi xenon included HID from steve?
Old 08-02-2004, 07:00 PM
  #580
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
BIX = HID
Old 08-02-2004, 07:02 PM
  #581
LaZyC230K's Avatar
Ooo... really? i though bi xenon is only the headlight assemblies which dosnt included all the bulb and stuff. sorry about my stupid knowledges
Old 08-02-2004, 07:11 PM
  #582
BIX includes everything. its plug and play!
not buy this, plug it in here, buy something else, plug that in there. then play!
Old 08-02-2004, 07:12 PM
  #583
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Old 08-02-2004, 07:13 PM
  #584
LaZyC230K's Avatar
hey, citron. i think the color of ur car is lovely. I love ur car, it is so nice
Old 08-02-2004, 07:16 PM
  #585
thanks! me too!
Old 08-02-2004, 07:29 PM
  #586
MBworld Guru
FrankW's Avatar
white and whiter
Originally Posted by CitronC230K_03
thanks! me too!
me three
Old 08-02-2004, 09:12 PM
  #587
xxbenzc230kxx's Avatar
is not yet completed
Originally Posted by FrankW
me three
me four
Old 08-02-2004, 09:19 PM
  #588
preyx's Avatar
'02 C230K Coupe
Back on topic: You want aftermarket HID application, but you want those covers on there to keep the moisture out. But of course you still need to run the wires. Solution? There is an HID accessory that is a rubber grommet with a slit in the middle to allow you to run wires while maintaining the seal on the headlight. This will require drilling a hole into the back cover to install this grommet.
Old 09-18-2004, 10:09 AM
  #589
antonleung's Avatar
GLK350
Aftermarket HID Xenon Kit problem
After I installed the aftermarket HID Xenon Kit, it looks great, but I always get a warning message on the cluster instrument, "Check low beam R lamp". My friend W202 has the same problem. Is it normal or do I need to go to the dealer to reprogram the ECU to "xenon present"? Please advice. Thanks
Old 09-18-2004, 11:10 AM
  #590
Super Moderator
MJ50's Avatar
bone stock E55 AMG
u have to take it to the dealer to set xenon PRESENT.
Old 09-18-2004, 11:16 AM
  #591
PRHeloPilot's Avatar
................ Bell Helicopter & '05 C230 SS
Yep, take it to the dealer. It's all computer controlled now and they'll be able to tell what's wrong....
Old 09-18-2004, 12:41 PM
  #592
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
He did say aftermarket kit. There could be more than meets the eye here. Especially if his message as posted is true; R only.
Old 09-18-2004, 12:49 PM
  #593
Wiedermann's Avatar
NA
Lightbulb Aftermarket HID problems???
Mr. antonleung:
As Mr. amdeutsch indicated, --and it is VERY likely--, there may be more than it meets the eye then just setting your system to Xenons "present. A similar problem did occur on someone else's car when they installed their "aftermarket" HID foglights... same scenario that you got in your display... please read below:
Originally Posted by Wiedermann
Front Right Foglight Error, why?
Mr. excess:
Originally Posted by excess
I just installed a set of HIDS on my front headlights as well as the foglights and the car is throwing an error on the front right foglight but it works perfectly it doesnt shut off or blink in any way, the headlights have no errors whatsoever nor the left foglight? What can be causing it and the possible fix?
I noticed if I turn the fog lights on before I turn the ignition on no errors come up but really want it to work the proper way
If what I am about to say it is true/accurate in whole or in part, you may be passed the "want it to work the proper way" part of your quote above.
If you have cut the wires on the fog lights to tap into the starters, ballast, etc, etc... then you may very well be stuck with the error for good.
On the "HID headlights" you mentioned, I am assuming it is NOT the MB "Bi-Xenon" headlamp assembly but instead another aftermarket HID brand. Depending on the type of installation used on your headlamps, you may encounter errors on the headlamps as well (after driving long periods ot time due to the overheating of the wiring associated with the headlamps)
Your problem "could" be fixed, but it could be costly, as you may have to re-run wiring harnessed to correct the problem
Note: Xenon is a registered mark of High Intensity Discharge (HID) lights, currently licensed and used by some German manufacturer brands.
Wiedermann
You (Mr. antonleung) may be able to correct the problem if it turns our that your "aftermarket" installation was done cutting the wires (which a NO! on MB!!) but it will cost ya!
Wiedermann
Old 09-18-2004, 12:54 PM
  #594
p010sp0rt8's Avatar
2008 Cayman S / 2002 C230
if the xenon present does not solve this problem. you can get inline resistors which will bump the resitance of the lights to that of the stock halogens... good luck
Old 09-18-2004, 02:53 PM
  #595
LaZyC230K's Avatar
i've also installed aftermarket HID too, but i have no problem with it and it works great, no warning sign and anything
Old 09-18-2004, 03:15 PM
  #596
Kev04C320's Avatar
'09 911 C4S
Which one did you purchase? My friends installed aftermarket with Hella ballast and worked fine, but another one tried Panasonic and got error messages.
Old 09-18-2004, 08:22 PM
  #597
CHATMANR's Avatar
Location: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Question
Old 09-18-2004, 08:25 PM
  #598
Originally Posted by CHATMANR
i love that smiley!
Old 09-18-2004, 09:31 PM
  #599
antonleung's Avatar
GLK350
My HID is Japanese product, but my friend is using Hella kit, he got the same problem too. My HID didn't flicker or shut down, but it just display warning message all the time. I don't have to cut any wire during installation, it is plug and play. Does any one can get the aftermarket HID works without reprogram the ECU to xenon?
Old 09-18-2004, 09:53 PM
  #600
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Some people have provided solutions/design changes: relays, resistors, etc. One of them even in this thread you started. STF
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
Quick Reply: Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
