Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
#651
Xenon-HID upgrade???
Hey guys,,
I would like to replace the highbeam, foglamp and running lights on my 2002 c320.. to HID Xenon. I have the Xenons for the low beams... and got some cheap "HIDs" on ebay for the fogs and highbeams,, but they already blew.. where do I get the replacement bulbs?? the real ones.. to match the low beams..
thanks
KC
thanks
KC
#653
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by superman2269
Hey guys,,
thanks
KC
thanks
KC
There is a company by the name of XENON that makes blue halogen bulbs, but you need to be a little clearer because your thread doesn't really make sense.
#654
Get a xenon kit, that's pretty muich the only way to really match other xenons.
On a side note, don't spend more than 250 on a kit, it's just not worth any more than that.
#655
HIDs
I just want the Fogs, highbeams, and running lights to match the HID low beams that came with the car..
where to find them,,
how much am I lookin at for everything..
thanks
sorry for the confusion
thanks
#656
thanks
thanks
1) You won't find ANY parking lights that will match the headlights with exception to LED white parking lights, however you will need a load equalizer in order to change the parking lights to LED.
2) There are several options that can come somewhat close, but will never be able to match the light output of Xenon headlights (low beam). I have a 2004.5, so I have the clear fogs and bi-xenons. The light output would be a little different, therefore my frame of reference is not the same.
I use NOKYA Arctic Purple bulbs in the foglights. I use NOKYA Arctic White bulbs for the high beams (halogen portion of high beam). I think the Arctic Purple bulbs I got are too purple, but still look better than the stock bulbs I had in there. NOKYA Arctic white match very well with the bix low beam, but since you have the pre-bixenon HID setup, you can probably go with a blue/purple light output.
There are several other options out there. This has been discussed several times throughout this message board. Do a search for "REPLACE FOGLIGHTS", "REPLACE BULBS", "REPLACE PARKING LIGHTS", etc...
I have PIAA 194's in my Parking lights, but they don't really match. They look much better than stock, but don't match.
Hope that answers your question.
#657
2005 White C230 SS
Philips Ultinon 6000K D2S installed!
Just installed Philips Ultinon 6000K on my car, here are some pictures, first one is the original 4100k bulb, rest one are the 6000k. it is white-blue compare to stock 4100K's yellow-blue, but not as bule as the Japanese bulb, I hope you guys like it~
#659
2005 White C230 SS
Originally Posted by W0n6_3d4n
How's the output compare to stock?? Lastly how much?? ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#661
2005 White C230 SS
It's a direct bulb swap if you have bi-xenon, I got it from Here It tooks me like half hour for the first one because I don't know how to put the bulb socket back, 2nd one took me 5 mins to put back~ help it helps~
#664
Too many to list
Originally Posted by LMing
I would say you lose 10% of vision compare to stock because everthing on the road is a bit bule now, but I think it's worth to lose those 10%
I paid around 250 US shipped. help it helps. thanks~
#665
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
Ultinons Rule !!
Originally Posted by diamondblak05
Actually, according to Philips, you would lose 25% of illumination because the stock 4100K D2S bulb is rated at 3200 lumens while the ultinon 6000K bulb is rated at 2400 lumens. I like the bluish/purplish/white color combination but when it starts to rain, you won't be able to see much of anything. Because of that, I swapped it right back to stock after a week. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Here is a picture of a 6000k Ultinon and a OEM 4300K which is the brighest and which is the phillips everyone ??
#666
Too many to list
Originally Posted by benzondubz
I agree that anything over 6000k is a waste you do lose some lumens. but this not being able to see in the rain is joke to me ? I run a S500 D2S HID projector with the 6000K Ultinons and it is *** X ray vision ... brighter than most peoples high beams. So something is wrong with your setup for sure diamondblak05 .. what setup did you run your ultinon and are you sure it was the non DOT deal ?
All your HID questions will be answered there.
#667
2005 White C230 SS
#668
if you live in a city where theres street lights at night dont worry about it, ive had 6000k and 8000k bulbs in before and at least in nyc you cant tell the loss of light
#670
Originally Posted by Tishers
I am confused. Why would you put bulbs in that reduce your visibility?
I know that there is some sort of coolness factor to it but it seems counterproductive.
#671
2004.5 C 230
Jkw
#672
Too many to list
#673
Originally Posted by Jkw
Just my 2 cents, But I would like as much light as possible on the road.
Jkw
Jkw
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#674
08' BMW E92 Coupe
i would not go over 6000k though. the philipps ultinons are great bulbs and i think although they are listed as 6000k, they are actually 5400 or 5600k. can't remember which one it is. had them on my bmw for 2 and a half years then sold them when i got rid of the car.
#675
08' BMW E92 Coupe
Just installed Philips Ultinon 6000K on my car, here are some pictures, first one is the original 4100k bulb, rest one are the 6000k. it is white-blue compare to stock 4100K's yellow-blue, but not as bule as the Japanese bulb, I hope you guys like it~ ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
