Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
#1226
Installing HID retrofit
I have a 2001 C240 sedan, w203 that is still using the halogen lamps/headlight kit.
I found a nice HID (xenon) kit from at Ebay from MTEC and they advertised that it is a straight install and compatible to the onboard computer with no requirement to reset.
My questions are:
1) Had anybody tried installing an HID retrofit at all and did it give any problems? A detailed procedure is appreciated.
2) I would like to know if there is a requirement to also change my headlight assy like the lens (reflector or projector - not sure) since I currently have halogen. As I read in forums, installing a xenon lamp might require changing the headlight assy as well because a halogen assy with xenon lamp might give glare to oncoming passenger, etc.
3) Is MTEC a reliable brand and they are as good as they advertised with no computer error?
My questions are:
#1227
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
My questions are:
My questions are:
1) Search the forum, it's been discussed. There's a WHOLE THREAD about aftermarket HID kits in the stickies at the top of the w203 forum. Please look through the AFTERMARKET/DIY sticky thread.
2) Where the heck have you been hearing or reading this. Again, please read through the threads in the AFTERMARKET/DIY sticky.
3) MTEC is pretty reliable. I have the halogen bulbs though, so don't know how good the HID kits are.
That being said, I'm merging this with the aftermarket hid kit thread.
#1228
I've been having some problems with my cheap hid kits from ebay. To remind you I had capacitors installed and worked like charm for awhile. But recently one side started going on and off by itself and it was dimmer than the other side? What can I do to remedy this? For the moment I had regular H7 bulbs put in after many attempts at fixing it but no luck...Will reprogramming 'xenon present' do any good? If I reprogram do I even need to add capacitors? I can't stand regular halogens. Will spening the money on 'quality' aftermarket ones like MTEC will do?
I have cheap kit for my other old car with basic wiring and never had any problems... mb just like to give me hard times with their cars.... difficult to mod them correctly
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#1230
Your thread title is so confusing. Retrofit normally means that you're reverting to put older parts on a newer model (i.e. 2005-2007 converted to 2001-2004.5).
Thanks for th reply, DREXAppeal. You will have to assume that I have no idea about headlights. I am only starting to learn them now. I have been searching this forum for a week and I did find the Aftermarket / DIY link which shows dozens of aftermarkets DIY. I only saw 3 topics on headlights and it didn't make much sense to me.
Can you make it easier on me and copy and paste me the link on the procedure so that I don't have to go searching??
Thanos
#1231
Thanos
Thanos
So, if you know how to remove a headlight bulb and replace it, you should be able to do this DIY very simply. If you DON'T know how to replace a headlight bulb (very simple DIY), I suggest you have someone help you.
#1232
Replacing headlight bulbs is the same procedure. The only difference here is that (assuming the kit is made for a w203 application) there is a ballast between the connector inside the car and the connector that is attached to the wires for halogen headlight bulb.
Great. I have replaced headlight bulbs before.
Let me just make sure I understand what you said clearly. If I buy the MTEC HID kit, all I have to do is the following:
1. Take out my existing halogen bulb and replace it with the Xenon bulb
2. Attach all the cables/connectors that came with the kit which should match whatever connectors that got pulled out on my original headlight assy
3. Find a place to permanently install the ballast
4. That's it!
Now I am not sure if you are aware since you mentioned in one of your threads about "where the hell did i read about changing the headlight assy (like the lens, reflector or projector, etc)." And i must admit that I did see a lot of topics about headlight assy itself not only on this forum but other existing MB forums.
From what I understand if I read it correctly is this: Since my original headlights were meant for halogen - that the lens or whatever is inside my headlight assy were all meant for halogen only. I read that halogens uses reflectors inside the headlight assy and for xenons, it should be using projector type.
Maybe I might have projectors inside my current halogen headlight right now - i don't know. How would I know that. Is there a simple way to determine if I have projector or reflector on my headlight assy?
Or does it really matter whether projector or reflector - HID kit will still work. My intention here is to install HID legally - without causing glare to oncoming traffic.
If it's only the first 3 steps I defined earlier that I have to do, it makes it look very easy for sure and I can certainly do that. But I wanted to make sure that there are no other complicated things to do like removing the entire headlight assy, etc.
Thanks and I look forward to hearing from you.
#1233
EVE
i'll take this one...
well you'll be causing glare no doubt... illegal? maybe if you get caught or follow the PoPo with the upgrade. It's painfully obvious on your eyes on who's got projectors and who's got retrofitted halogen HIDs.
These are projectors - if you don't have some variant of this, you'll be glaring and won't be able to properly level the beam (if you don't care about this, then I can't stop you).
Otherwise your steps are about right on the install... it's pretty easy and there are multiple DIYs as Drex suggested.
flip
flip
#1234
flip
flip
#1235
1. Take out my existing halogen bulb (and socket) and replace the bulb and socket with the Xenon bulb and connectors.
4. That's it!
4. That's it!
Just didn't want people who haven't done this before to think that they could just swap a halogen bulb with a xenon bulb, using the same socket, and have a HID upgrade. In essence, you'll be replacing the socket/bulb and wiring with the Xenon bulb, connector and wiring (which would be connected to the ballast).
#1236
I made some slight adjustments to what you stated, but in essence that is correct.
OK, I would presume that since you did not comment anything on the headlight assy which consists of lens/reflector/projector, etc, it means that I don't have to touch anything on it and it should work even though it was meant for halogen, right?
Thanks again.
#1237
Thanks again.
Thanks again.
Those that haven't done this, either did Halogen bulb upgrades or they have BI-X.
#1238
2003 C240
Hi,
I'm going to be installing HID in a couple weeks, and wanted a confirmation on these pics Cloudz posted wayyyy back in this thread. Is this the best location for the ballasts? I've read in this thread that the ballast being near the ESP (2nd pic) can cause problems, however there really isn't much more room on the driver's side. Please advise. TIA.
![](https://mbworld.org/forums/attachments/c-class-w203/100933d1174522515-aftermarket-hid-conversion-kits-required-setting-xenon-present-thread-dsc00085.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/100934d1174522515-aftermarket-hid-conversion-kits-required-setting-xenon-present-thread-dsc00084.jpg)
#1241
2003 C240
#1242
01' C32o
i ziptied it, i'll have pics up if you want to see how i did it. it's in the same general area, hoever it isn't close to the ESP, or as close to it as cloudz.
#1243
2003 C240
#1245
just wondering how many dealerships did you guys have to go to before you could get one that would switch your xenon setting over and how much if anything did you have to pay?
my local orlando stealership said it was about an hour of work and that they couldn't do it in the drive lane that they would have to bring it in so i was looking at around $147 for labor.. i'm calling
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
#1246
my local orlando stealership said it was about an hour of work and that they couldn't do it in the drive lane that they would have to bring it in so i was looking at around $147 for labor.. i'm calling![bs](https://mbworld.org/forums/images/smilies/bs.gif)
If the dealer refuses to assist you, you can mention something about safety hazard to drive the car with flickering headlights at night.
#1247
well the thing is that the dealership is already 30mins away and then the next closes is probably alteast an hour away.. but when i head back home i have like 3 within 30min so i'll try the just drive up method there
#1248
01' C32o
yeah, just print out the pictures of the steps! that is the crucial point, my dealer said they would charge me, and viola, i drive up, bring out the printout and showed him. he said damn, that's easy, took my car in, came out in 3minutes and said here you go! lol.
#1249
It is at most 10 minutes of work. It is too bad that many techs don't know where to go in the menu's to find the settings.
#1250
2003 C240
Hey guys, I've read this thread several times, but I was wondering if anyone could give me some current opinions on the Stealth Auto Slim HID kits. Thinking about getting a couple sets because I'm not very happy with the ones that came with the DEPOs. TIA
