Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Old Mar 18, 2009 | 01:14 PM
  #1626
NOMO's Avatar
CLK 320
So I just had my Xenon set to present I plug the only plug i see in and .... No Xenon I get blinkers and high beam, but that's it.
Old Mar 20, 2009 | 06:01 PM
  #1627
NOMO's Avatar
CLK 320
Looks like the ballast needed to be grounded to the frame... I don't get it, but I got them installed and working. Hope that helps some one else having the same problem.
Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread-mail-2.jpg
Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread-mail-2-1.jpg
Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread-mail-1-1.jpg
Old Mar 27, 2009 | 05:38 PM
  #1628
jmiholich's Avatar
2005 c230
I just ordered mine from www.xenonkits.com. I should have them by next week. I'll take some pics and give you my thoughts.
Old Apr 15, 2009 | 02:12 AM
  #1629
kobe1980's Avatar
2007 C230 Sport
jmiholich, how'd they turn out?
Old Apr 16, 2009 | 10:29 PM
  #1630
jmiholich's Avatar
2005 c230
HID Lights
They turned out great! Super easy to install. I just had to make a small 1.5" cut in the plastic cap where the rubber grommet (supplied) goes. I used my dremel tool. Probably took 30 minutes. I uploaded a pic of the diff from old to new. I may purchase the fog and high beams too. Great company to deal with. I also purchased the resistor kit that is plug n play. It just plugs inline with the new system. These are super bright lights. I'm sure they would even be better with a projector housing.
Attached Thumbnails Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread-img_0190.jpg
Old Apr 17, 2009 | 01:40 PM
  #1631
oo3's Avatar
oo3
Silver 2005 C230k
Man, so I bought the 55w kit and installed it. The first night everything was fine. The next day the lights started flickering...anyone else have this problem? If so how'd you fix it?
Old Apr 17, 2009 | 02:07 PM
  #1632
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
When you say flickering, you mean turning on and off really fast? Where did you buy your 55w kit from?
Old Apr 17, 2009 | 02:51 PM
  #1633
oo3's Avatar
oo3
Silver 2005 C230k
Yeah, it turns off then on. I bought the kit off ebay for 75 shipped. I may just go to mb and see if they can activate the xenon setting.
Does anyone have a DIY for the resistor fix for HID's? Or if anyone has a link to a dealer that sells HID error correction kits would be good too. I can only find one site but it's in Europe.
Old Apr 18, 2009 | 01:07 AM
  #1634
LILBENZ230's Avatar
I'm not sure why you have a problem with the 55w kit. I have the same car as you with a 55w Apexcone kit.. no issues. And in my car xenon is NOT set to present, and I have no resistors or anything of the sort. Nor did they come built in (sold separately for $40).
Old Apr 18, 2009 | 08:33 PM
  #1635
oo3's Avatar
oo3
Silver 2005 C230k
K I think I figured out why I got the error. The cover that goes over the back of the headlights were crimping the wires. I ended up cutting a hole big enough so the wires can move freely and it has worked ever since.
Old Apr 18, 2009 | 11:58 PM
  #1636
Tangerine's Avatar
Is @ Home
Someone should compile a list of which HID kit works without any error codes. I know that my Siemens HID kit work, selling now though.
Old Apr 22, 2009 | 01:08 AM
  #1637
oo3's Avatar
oo3
Silver 2005 C230k
Originally Posted by clairezeng
hi guys,take a look at www.tdlhid.com ,we will find more about the HID xenon conversion kits ..
Add 4% for paypal? hmmm...
Old Apr 22, 2009 | 01:27 AM
  #1638
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
moderators...time to do your jobs and ban the spammer.
Old Apr 29, 2009 | 10:02 PM
  #1639
linkmustang's Avatar
whaat kits work
what kits work i have a c230 coupe with new 05 lights that are clears and the clears fog light lens what headlight kits work
Old Apr 30, 2009 | 12:14 AM
  #1640
oo3's Avatar
oo3
Silver 2005 C230k
I also have an 05.
I bought a 55w kit off ebay for 75 shipped. It works great as long as you do not set your lights to Constant. Whenever I try to use that setting, the head lights will flicker and give off an error message.
It could be because the kit is from China...but overall it works great and I love the 55w brightness. Bought the kit from just_plaza http://cgi.ebay.com/HID-Xenon-CONVER...QQcmdZViewItem
Old May 18, 2009 | 01:01 PM
  #1641
Why page is the how to on I'm using my phone to seacj and its taking way to long to find it thank you
Old May 20, 2009 | 06:13 PM
  #1642
IntoTheBlue's Avatar
2005 C230 Sport
ok there's a lot to go through here....is it safe to turn xenon=present on if my HID kit is 55W? or is that setting only when you have 35w HID ballasts?
Old May 20, 2009 | 07:00 PM
  #1643
LILBENZ230's Avatar
You can turn Xenon=Present on regardless. Even if you have halogens, it won't affect it.
It is interesting to note the other guy that has posted on this page that says his 55w kit works unless you use the headlights = constant feature. I'm gonna go try that.
Old May 20, 2009 | 07:43 PM
  #1644
londonbenzkid's Avatar
2002 C240, 2006 ML350, 2011 X3
if you guys need resistors / capacitors i bought these ones... for 30$ shipped.
http://cgi.ebay.ca/2x-HID-Kit-Comput...3%3A1|294%3A50
Anyways,... my kit is the 35W from VVME.com
It flickers, and i get the low beam check errors, so i got these error cancelers,.. hopefully they work,... they are shipped but have yet to get them.. I will post back if they work.
Old May 20, 2009 | 11:48 PM
  #1645
LILBENZ230's Avatar
As you can see the VVME kits are not fool proof. It's so inconsistent.
IntoTheBlue - my HIDs work even with the DRL feature enabled in the settings menu.
Old May 21, 2009 | 06:32 PM
  #1646
xxhanxx's Avatar
2005 c230 k
hey this is my first post and new to these stuff.. i ahev been reading for the pass week and have not yet need to post untill today! i just got my w203 (2005 230 K) week ago so am noobie to these car modifications. my friend who works for a mechanice for Porsche ordered DDM HID kit (h7) bulbs for my low beam... i was reading on the forum and was aware of the flickering issue and told my mechanic friend about it.. but was told it was high quality hid kits so it wouldn have a problem... but we installed it and it flickered damn it.. soo now... i guess i have 2 optiosn right?
1) go to mercedes to reprogram it to xenon = present... how much would it cost to do this? would they do it?
2) buy DDM HID warning Code eliminator.... i am wondering how many of u guys out there have experienced this item and if it works.. thanks
and my mechanic friend already ordered the kit for fog lights... would i have flickering issue with teh fog lights as well? will i need to get the Warnign code eliminator too??
Thanks guys!
Old May 21, 2009 | 08:04 PM
  #1647
2005 C230 Sport
xxhanxx, here's my situation. i got flickering with the DDM 55w kit, so ordered the warning code eliminator and now my HIDs work but NOT when i have daytime running lights on (headlights set to constant in the dash menu)
So if you intend to have your headlights turn on everytime you start up the car, you'll have to go to the dealer to get xenon=present, because for me at least, the warning code eliminator doesn't work for that.
Old May 21, 2009 | 09:31 PM
  #1648
samaritrey's Avatar
Super Moderator
THE C350
ok first i have to thank you for not making a new thread on your issue. and second thank you for reading. if you have the 35watt kit i would recommend you go to the dealer explain that you need to find a good dealer to work with since you just got the car. tell them that you need a setting changed and they will most likely do it for you and make sure you go at an off time so that they will not have to rush and more likely not charge you. it also helps since you are new to the dealer to go talk to a sales person and ask for the best service advisor. also it helps if you put your location in your profile so that we can help you find the best dealer. if the dealers around you won’t help you can find a shop that specializes in mb and they will usually have a star computer. it also helps to print out the location of the setting so that they can change it quickly with little effort. I will post it here for you if I can find it. Good luck and hope you are enjoying your new car!
1. EIS- Electronic Ignition Switch
2. Control Unit Adapations
3. Read Coding and change if necessary
4. All Codes
5. Xenon Headlamp- (Change to "present")
thanks to C230 Sport Coup
Old May 22, 2009 | 01:31 AM
  #1649
xxhanxx's Avatar
2005 c230 k
thanks for the response, yea im probably gonna go to MB and switch it to xenon = present first since i have a 35watt kit in my trunk and see the outcome. i live in canada vancouver bc so day time running lights are always on... i cant avoid the issue.. i cant even install the lights first then drive to the dealership to change it... haha i have to go to the dealer ship frist then change the bulbs after..
how about the xenon fog lights. will it flicker?
Old May 22, 2009 | 05:13 AM
  #1650
LILBENZ230's Avatar
About the fog lights - the car is capable essentially of detecting every single bulb on the exterior of the car. I got an error stating my left license plate light was out. So most likely if you put in 35w fogs it will flicker without error cancelers.
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
