undervoltage error ..stranded and need help
I got that error message to but after i pump up my stereo system for hours. I think you battery is not charging right. Try driving your car around and see if the battery is charging if erro meassage come up again then something worng with your battery.
what do you guys think is it the battery? or could it be the voltage regulator or alternator? also can anyone tell me where the voltage regulator is on the car and how to replace it? i'll take the battery off tomorrow and get it checked but if it checks out ok my next step will be to replace the voltage regulator since its cheap..if all fails i'll replace the alternator...oh my car is a 2001 c240 btw
thanks
I use equipment that looks at all 3 legs of the alternator output (at a single post for the wave pulsation from the diodes) when I made a decision to replace. I can normally tell if it is diodes, regulator or alternator itself. But if you don't get the voltages above you probably just need a replacement. Jim
Go back to stock, and see if you still have a problem.
Otherwise, how old is the battery?
Maybe it's not charging?
If it's old, it can short and drag the whole system down, and cook other things too.
The midronics test if i remember correctly is done with the engine off, so only tests the battery not charging system.
I use the snap-on microvat, nice tool, I had to many odd readings and problems with the midtronics tester at the dealer, mainly due to one or two testers being passed around (read dropped) by 40 mechanics.
The main reason the dealers use the midtronics is because MB require the printout from it for warrenty claims. Most tech's i know prefer the snap on tester. Just my $0.02 worth.
The headlights should do nothing. Total BS. Maybe it's a coincidence? That is weird indeed.
Keep us posted.
