Rear view turn signal and phantom wipe !!!
Every now and then i'll get a message of faulty left turn signal as soon as i select it, when it is left on for more that 3 seconds it will go away. I steped out of the car once as the message came on and the rear viewturn signal was out. With my wipper select switch in the Auto feature the wippers will once in a blue moon wipe with out any rain falling on them. I took the car to the dealership and they had it there for 4 days. They replaced the multifunction switch that controls the cruice control, wippers and signal lights. I picked up the car last night, today its doing it again.
What can this be? I'm pretty good with cars and i think it might be a shorted out light bulb in that rear view mirror but, they dont think so.
Thanks in advance.
Eddie
check the DIY sticky. find the mirror cover replacement, you may have a lose wire.
good luck and welcome to the boards
Thanks in advance.
Eddie
1) the phantom wipe is an easy one... you leave it on AUTO feature and it's going to do that occassionally. Just like noted above, if it's not raining, turn it off.
2) update your profile on the left, with your year & model, and location where you live. This helps people better answer your questions, because not all the features & problems on C models are the same throughout the years. As for location, this helps forum members troubleshoot why certain things may be occurring, and can direct you to local help or dealers.
3) as for the LEFT turn signal fault, it's either a disconnected wire or a burnt out light. I don't understand why the dealer replaced the entire multifunction switch that controls the cruise control, wipers and signal lights. Didn't they just check the connection to the LEFT turn signal ???
What makes them think that it is NOT a shorted out light bulb ???
Didn't they see what you saw ( that the signal was out) ???
Sounds to me that either the dealer is clueless, or you didn't explain correctly what was wrong... Maybe they assumed the two (signal error and phantom wipes) were somehow related. But even so, you would think that they would try to re-create the fault, and then troubleshoot, rather than just "let's replace the entire switch" option.
Carlos
Saprissa@aol.com
Thanks in advance.
Eddie
Carlos
Saprissa@aol.com
2. Profile updated. Thanks
3. I explained the problem just like i did here, the tech told me he could not duplicate what i was seeing so, he went ahead and replaced the whole thing. He told me he though that they were related for some reson. I have to take it back today and i guess they will replace the light bulb or check for the cables this time.
Thanks for all of your help.
Eddie
