Wheel help
Old Oct 1, 2002 | 12:04 PM
Benz's Avatar
2000 F-150 XLT Sport Crew Cab
Wheel help
Will these wheels and tires fit on this car (2002 C-230)
They are E430 wheels with the tire size 215/55-16
The tire size on the 2002 C-230 is 205/55-16
I believe this will fit, but can anyone verify this?
thanks
Old Oct 1, 2002 | 02:40 PM
patronus's Avatar
2001 C240 / 6-speed
We can only help you if you tell us the wheel width and offset.
Old Oct 1, 2002 | 03:21 PM
Benz's Avatar
The offset is:
16x7.5 ... So do you think 16x7.5 will fit on the car?
thanks
Old Oct 1, 2002 | 03:29 PM
patronus's Avatar
2001 C240 / 6-speed
Actually, 16 is the wheel diameter, 7.5 is the wheel width.
The offset is where, axially, the hub mounts to the wheel. It is stamped on the back of the wheel and is usually identified by an et (like 35et).
Old Oct 1, 2002 | 11:42 PM
Benz's Avatar
I think its 112mm I have no idea LOL..I wish i knew my own tire offset LOL
Where is it located on the wheel?
Old Oct 2, 2002 | 12:46 AM
patronus's Avatar
2001 C240 / 6-speed
112mm is the bolt circle diameter. The offset is stamped on the back side of the wheel.
My hunch is that it will not fit. With a 16x7.5 wheel the offset should be about 35mm (+/- 2mm). I think that the W210 wheels were in the mid-high 40's offset. If that is the case, the tire will rub in the wheel.
Old Oct 2, 2002 | 12:50 AM
Benz's Avatar
My wheels are 16x7.5..I believe the 2002 C230 are 16x7.5 also..
Old Oct 2, 2002 | 12:55 AM
patronus's Avatar
2001 C240 / 6-speed
Yes, but the offset is of CRITICAL importance. This dimension is the measured between the center of the wheel (looking front to rear) and the surface that it mounts to the hub.
If this dimension is wrong, the wheel will either stick out too far and rub on the fender or stick in too far and rub on the suspension.
You really need to find out the offset before you buy. If it is outside of the 33-37mm range, they won't fit. PERIOD.
