2005 C230 SS Harmon Kardon System - Break It Down
My first question is does the Harmon Kardon system use fiber optic connections like the Bose?
Are the any impedance issues with the speakers?
Finally, does the 2005 system put out 320 watts like the 2007 system?
I'm asking these questions because although the system is decent, it lacks both the clarity and punch I would like, and I want to know what I would be getting into if I upgraded certain components. Thanks.
http://www.ragtop.org/mbbrochures/2005/csportclass.pdf
Oh snap! Had most of the info I was looking for. So it appears, we have a 320 watt "7.1" channel amp and fiber optic connections between headunit, cd changer, and amp.
So now my questions are:
1. What the hell are the benefits of a 7.1 channel amp without being able to play dvd's, cd's dont use 5.1 let alone 7.1.
2. Can we still get a new head unit to connect to the amp, or does getting a new head unit mean forget about using the amp (I suspect a better headunit would clean up the sound a lot, however I don't want to lose the 320 watt amp)?
3. If I simply add a powered sub by tapping into the stock sub speaker wire, will the stock sub still play?
i checked out that link at the top and some of the 05s came with a 12speaker system plus sub. Any ideas? Thanks. Car sounds good though :thumbs:
There are two tweeters in triangle grills on the front doors. There is a speaker in each door that has two voice coils for mid-range and bass sound. There are dual coils on the subwoofer as well. That makes a total of 12 speakers, but they are contained in 7 packages.
Cars with tele-aid have a separate speaker behind the right kick panel. It only works with tele-aid.
The main amp has a microphone input that adjusts the sound volume when ambient noise changes. The mic is located toward the front above the headliner on the passenger side.
The 320 watt claim is as optimistic as the EPA mileage figures. The amp is probably closer to 36 watts RMS.
Unlike the Bose speakers that used odd impedance voice coils the HK units can be changed to after market speakers. There is little out there that is better, but sound is a subjective science so you might find a speaker that sounds better to you. Changing the speakers will most likely change the engineered response built into the factory system, so you might not like the result.
If you need a bit more thump for the rump a HK BasslinkII in the trunk is an excellent choice. It can be adjusted, and will take its input from the rear door speakers. It is not a good idea to take the input from the sub wires because that sound might miss the response of the BasslinkII 10 in sub.
You can through the head unit adjust the amp. It will remember settings for CD, Radio, and Aux input independently of each other. You can also set it to "surround" mode to take advantage of the 7.1 feature. There is no actual center channel, but it is created by software in the DSP (digital signal processor.)
Changing the head unit will not "clean" anything. The tuner is top of the line, and the quality from the CD player is a function of the CD's. You can adjust the bass and trebel controls for each sound source to find what sounds best to your ear.
You would lose the amp if you changed the head unit. You would need an additional amp to just equal what you have now.
this are my thoughts on the H/K system, having lived with it for over a year now: the mids/highs are pretty good. listen to jazz, or classical and it sounds pretty good. bass sucks, that little woofer dont do much. plus the rear hatch rattles like CRAZY, dealer wont fix it under warrantyt, they said they did, but its the same. the 'surround' sound, does have its merrits, u get deeper bass when u activated it. like it isolates the woofer. u can even feel it in the back of ur seat just a bit. but the mids/highs become muddled when u turn the surround on. i wish the head unit had eq or better settings like woofer control etc. but i guess too much to ask for stock even if it is premium. I have the AUX input set up in my car, and it sounds pretty good. not yuky but not great.
ok about the basslink. i read elsewere on this forum to take the leads out of the woofer not the rear door speakers. wouldnt it make more sense to come out of the stock woofer leads and take that little woofer out of the equoation altogether? plus isnt the signal comming to the woofer of a lower impadence like the basslink II would like better? and how would you control the basslink II form the headunit? do u mean the Bass control? i would rather have an independant woofer control.
thanks for the info!
C class is notorious for having a rattle in the package shelf when peeps operate the sub at higher volume, with music created with real bass. The answer is sound deadening. You need both a butyl mat and Ensolite to make the rattle stop. A special spray adhesive is used to apply it. Stuff works great. Makes the car even quieter if used in the doors and trunk.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Just a question...
The package shelf is rattling because of sympathetic vibration, and will still rattle with the new sub, so sound deadening is necessary. You might complain to Mercedes about the rattle before you do anything, and encourage them to fix it.
There is an amp in the head unit for cars without HK premium sound. That amp is silenced when the head unit is version coded for premium sound. The volume, bass, treble, balance, and fader controls are remapped to operate the remote amp. If you would like to add speakers, get a quality class D amplifier.
https://mbworld.org/forums/showthread.php?t=225056
Thanks for that! For some reason my search feature doesn't work right... and doesn't work at all if I search for a phrase with the word "rear" in it... It just goes to a blank screen! Really Weird!
