Front wheel camber when turning
Old May 21, 2007 | 10:01 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
I tried a search but could not find what I am looking for.
The other day when I parked my car my wheels were hard over left (all the way) and when approaching the car the front wheels are severely tipped over, so much so that the inside edge of my 225/45 17 did not even contact the ground.
I know that this is part of the design or engineering but what is the reason for this. I can't see any advantage except for tire manufacturers as you are going to wear out the outside edges. There is definately less contact area so I would think that this would comprimise handling unless you have severe body roll. It also seems that when you turn hard over at a standstill the height of the front of the car gets higher.
I've seen this tipping effect on other cars (BMW) and other Benz's but not to the degree as on our C class. It does look extreme in that several times people have commented wondering if I have something wrong with the car ie the front strut broke. (the car is fine and nothing is broke)
Does anyone have a theory on this or the purpose?
Old May 21, 2007 | 10:55 AM
e1000's Avatar
a quarter mile at a time
lookup "caster"
http://mercedesshop.com/shopforum/sh...ad.php?t=39285
Old May 21, 2007 | 01:34 PM
trisonics's Avatar
2002 C230K Coupe
I was about to start a thread on this topic and found this. I noticed the camber only yesterday and was wondering if it is by design or something broke on my car.
The wheels look like this when parked and wheels turned all the way to the left:
Old May 21, 2007 | 10:01 PM
johnnyquest's Avatar
When the car is moving at speed the downforce loads the suspension causing the tires to have more contact with the road.
Old May 22, 2007 | 12:52 AM
sim_benz's Avatar
mine: '01 C240 w/heavy modifications dad's: '05 997 Carrera S
yeah, ive noticed this, even with my HR cup kit, and ive come to the conclusion that when cornering at speed, the centrifugal (ok...technically centrepital, for all you physics buffs out there...but w/e) force pushes the car toward the outside of the corner, making the tilt you are seeing a good thing because it cancels the tire roll effect of cornering.
Just think of the force you feel in the car when cornering, well the entire car is being acted upon by that force, so I can only assume that the tilt is designed to make it so that force only plants the tires firmer and flatter on the ground. Its a way to use what is normally a negative cornering force to reinforce the traction of the car.
Thats the best I can surmise after thinking about it seriously when i saw that more than just my car did it.
Old May 22, 2007 | 02:43 AM
Stormin's Avatar
'06 SS
And you'd be right.
Under lateral loading, the centripetal force will cause more of the tires surface to be in contact with the ground.
I commented on the design before I even left the dealers lot with my first 203 in 2005.
Old May 22, 2007 | 03:07 AM
hawaiian's Avatar
2003 C230K SS (6 spd)
Correct me if I'm wrong but I believe the design is for a tighter turning radius. In 2001, my friend came back from Germany w/ an 01 BMW 325i which did the same thing; he related that to such a tight turning radius which is what the dealership told him. Next time you're parked along a curb, turn you're wheel to the max and proceed to bang a u-ey. You will then appreciate the turning radius your vehicle has.
Old May 22, 2007 | 03:19 AM
e1000's Avatar
it's the caster that's built into the front suspension. caster helps stability at high speeds. the byproduct of high levels of caster is the "tilting" of the front wheels when turned.
the tight turning radius of our cars is simply because since it's a front engine, rear wheel drive layout, there is more room to allow the front wheels to turn further than typical front wheel drive cars.
Old May 22, 2007 | 03:38 AM
hawaiian's Avatar
Well I stand corrected, thanks for clearing that up.
Old May 22, 2007 | 04:50 PM
atai888's Avatar
06 C230 Black/Ash
Thumbs down
So does this "caster" make the tire wear on the outside???
I have only 16,xxx miles on my 2006 c230 and my tires are completely worn on the outside area of the tires...... (both front tires)
Old May 22, 2007 | 05:23 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
No, if you are wearing the outside edge (very outer tread block) of your tires you probably have too much positive toe (Toe-in). If you are wearing the outside half of your tires you have too much positive camber. Either way, you need an alignment.
Old May 22, 2007 | 05:58 PM
e1000's Avatar
if both the outer and inner edges are worn, your tires are underinflated.
Old May 22, 2007 | 10:56 PM
neilsam's Avatar
Registered User
2005 C230SS 6spd Blk/Blk, 2006 C350 SS 6spd Blk/Blk
Same problem here after 18,000 miles and my tires are inflated to about 32 up front instead of the 28 suggested by MB.
I don't think the wear on both inside and outside of both front tires is because of low inflation. More like a design flaw.
Old May 22, 2007 | 11:54 PM
sim_benz's Avatar
unless you have completely stock everything, then you should recnsider youre pressures, i think. I run 36 in front and 38 in back, and I get pretty even tire wear...
(assumes no responsibility if you kill yourself because your tires are overinflated)
Old May 22, 2007 | 11:58 PM
Boom vang's Avatar
You must have a very harsh ride with pressures like that.
Old May 23, 2007 | 12:06 AM
sim_benz's Avatar
actually i quite like it, granted im not driving on clouds, but I like a bit of road feel, and im not running 19s so its not bad harshness wise
Old May 23, 2007 | 12:44 AM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
That's why Benz has the best turning radius out of any car I've ever driven. I've seen this with all the Benz's owned in my family from a 450 SLC, to a 300 SEL to a E320 (w210) to my C230KSS (w203) to a CLK320 (w209).
When you turn the wheel to full lock one way or the other, the wheels angle to allow for the great turning radius, but I can't think of any situation a person will be in where they will be travling at a high speed and then torque the wheel to lock (left or right). That would make the car roll for sure (not sure if that's even possible).
As for negative effects, I can't think of any, just because the fastest anyone would be traveling at full lock would be 10-15 mph, making a u-turn.
Old May 23, 2007 | 02:04 AM
Stormin's Avatar
'06 SS
At which point the cars rear drastically attempts to catch up to the front.
I can think of a situation where I had the wheels at full lock at a decent speed...
We had a lot of fun that day...
Old May 23, 2007 | 09:54 AM
Cintoman's Avatar
2005 C230WZ SS Capri Blue/Ash
Yes, I had seen this before on other Benz's and thought something was broken on the front suspension. And then I noticed it on my car (05 C230WZ). But what made me put 2+2 together was when my uncle was showing my dad and I his new C (97 W202), and showed us how he could pull a u-ey on his street without having to do a 3-point turn. He did it, and his street isn't that wide at all.
It's funny the comments you get from people when they see your car parked with the wheels turned completely. They think something's wrong, but when I tell them about the turning radius, they are rather amazed.
Old May 23, 2007 | 11:58 AM
drexappeal's Avatar
Hahaha...that's awesome (okay, so there are exceptions to the rule).
Old May 27, 2007 | 11:37 PM
trisonics's Avatar
2002 C230K Coupe
Look at the 'camber' in my wheel... this is perfectly normal even at standstill? The outer edge of the front right wheel has excess wear compared to the left wheel. I swapped the wheels so you can see the excess wear on the left wheel now. I am thinking something is wrong...
Old May 28, 2007 | 09:58 AM
drexappeal's Avatar
It's more difficult to tell the "camber" of a car from the angle of picture you have. It's much easier to tell camber from straight on shots. Just because your front wheel is turned almost to full lock, doesn't mean that your car has camber issues.
Old May 28, 2007 | 01:57 PM
trisonics's Avatar
2002 C230K Coupe
I know it is difficult to tell from these angles but from other angles you cannot even see that. The tilt or camber is there only when the wheels are turned not when it is straight. But as you can see from the pic, the outer tread is worn out. This was originally the right side wheel which I swapped with the left. The left side wheel did not have any tread wear. I am thinking this is the reason for vibrations at high speeds and excessive road noise at low speeds.
Old May 28, 2007 | 03:35 PM
drexappeal's Avatar
That's not camber that you are describing. From what you're describing, that is how Mercedes steering is designed. That is what allows for the car to have such great turning radius. And as I had mentioned earlier, the only time you would be turning from lock to lock, the car wouldn't be going that fast.
Now as for the tires being on the edge at full or almost full lock, that shouldn't cause uneven tirewear. I would check the max tire pressure and increase accordingly. Lower tire pressure does cause for uneven tire wear. OR alignment/mis-alignment.
Old May 28, 2007 | 08:20 PM
trisonics's Avatar
2002 C230K Coupe
I know I know, it is not camber... the only time I saw camber on a street car was on the rear wheels of a Z4. I was just using the word to describe tilt. Anyway, I checked the tire pressure and it was 29 on both front tires but only the right tire is wearing faster than the left. The alignment is fine, had a mechanic check it before I purchased the car. Oh well, I will probably have a MB mech take a look at it when I get the other issues fixed.
