Resonator??
Old Jun 12, 2007 | 01:47 AM
  #76
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by Drop-a-Daimler
I put in a 3" pipe.
Ah, how's the airflow? Did you by any chance get dynos done before you did it? I'd be curious how it is on a NA car. Usually you'll see 3 inch piping on force enduced cars.
Old Jun 12, 2007 | 04:47 AM
  #77
KleanC's Avatar
White C
Originally Posted by sim_benz
from what I hear, the res only makes it lower, and the wy the eisenmann makes it sound...it wont be ricey....believe me....but I can always just post in 3 days to tell you this same info. Ronce has an aftermarket with res delete, and his souns like a friggin racecar, a littttttle too loud for me, however not ricey, just racey.
Im guessing from your sig..youve deleted your res already...How does it sound??
Old Jun 12, 2007 | 09:05 AM
  #78
Drop-a-Daimler's Avatar
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
Originally Posted by drexappeal
Ah, how's the airflow? Did you by any chance get dynos done before you did it?...
The motor runs great without the resonator. Plus it drops maybe 20 lbs. But it's no turbo or anything. I can't imagine it adds much HP, maybe a couple if any. No dyno. I might have it dyno'd when I do the ECU and headers. That would be interesting.
Old Jun 12, 2007 | 09:22 AM
  #79
sim_benz's Avatar
mine: '01 C240 w/heavy modifications dad's: '05 997 Carrera S
getting my car back from eurorev and Im gunna run it over and delete the cat at AAA exhaust...so i dont know what it sounds like YET...ill know in like 2days tops and post here...and as soon as i get that new-fangled youtube figured out i may post a vid.
Old Jun 12, 2007 | 01:20 PM
  #80
drexappeal's Avatar
From my experience with Normally/Naturally Aspirated cars, 3 inch piping is too big and it causes a loss in power, but if it seems to be working then maybe your car dispels the "myth" about bigger piping on NA vehicles.
I was actually considering getting custom cat-back piping made, but I don't think it's necessary for the 230K (m271).
Old Jun 12, 2007 | 02:41 PM
  #81
From my experience with Normally/Naturally Aspirated cars, 3 inch piping is too big and it causes a loss in power...
I went with the stock size pipe, 2 1/2" inside. I think you are right, bigger (in this instance) is not always better. Good cylinder filling and emptying (as well as scavenging) has more to do with the velocity of the charge and not the volume of the charge of air that is moving through. Exhaust pipes that are too big can hurt back pressure and kill any scavenging after the exhaust valve(s) open. I think you really want the size and shape that will produce maximum velocity so more air packs in and is drawn out on the exhaust stroke.
Old Jun 12, 2007 | 02:45 PM
  #82
drexappeal's Avatar
Hahaha...sounds like a porno!...
But, in all seriousness, yes that's similar to what I've learned over the years. Considering the stock piping is somewhere between 2.5-2.75 on the 230k ss, I'm very pleased with how it responds, especially with the Kleemann Trap muffler.
Old Jun 12, 2007 | 03:59 PM
  #83
All this thread needs is a cheesy sound-track. But I tell ya, all this talk of great sounding mufflers, when (if ever) will there be a few options for the 3.5L W203?!? I have found over a dozen that say they fit the C230, C240, C320 and C32 and maybe one that says it will specifically fit the C350. Anyone know of a good sounding muffler that will definitely fit?
Old Jun 12, 2007 | 04:26 PM
  #84
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
You know what? The piping on the 350 looks bigger in diameter than the other models. Is it just me that thinks that? Looks like 2.75-3. Or maybe it's just the angle of the pictures.
That looks about the same size piping that is on my 07 C230. 1st thought I had, was that piping is too damn big for a small 2.5L motor. When I get a chance, I'll put a micrometer on it and measure the diameter.
Old Jun 12, 2007 | 05:43 PM
  #85
drexappeal's Avatar
Actually, from what Cory (Kleemann USA) had told me, the trapezoid exhaust will work for the V6 models also as long as the piping is close enough in diameter. If this fit, I'm sure all the other makes (i.e. Remus, Brabus, Carlsson, Weltmeister, Eisenmann) would work...just check the piping size first.
I think it was the best decision I ever could've made picking the Kleemann muffler. Very deep sound, don't need to take off the resonator and is a pretty straight through design. And I love the trapezoid tip because it's unique compared to the others.
Old Jun 12, 2007 | 05:50 PM
  #86
drexappeal's Avatar
He said he put in 3 inch piping, so he's got custom piping. As far as I know (unless they changed it), stock piping is somewhere between 2.5-2.75 stock on the w203 (I think sport models, but may be across the board).
Old Jun 13, 2007 | 07:20 PM
  #87
gregr09's Avatar
non-MB
Well...I said screw it and decided I could always get the resonator put back on. I can tell a difference when driving; the sound is more present. In the before and after videos I took, there's not much difference. If anything, it removed some weight.
before
http://www.youtube.com/watch?v=ENqf3jGRxkM
after
http://www.youtube.com/watch?v=ueKZzzHDIog
Old Jun 13, 2007 | 08:03 PM
  #88
ScottW911's Avatar
a C32 AMG & S-Works Tarmac
before
after
Yup, just as predicted. The "after" sounds growlier. Much nicer sound without the resonator.
Old Jun 13, 2007 | 08:10 PM
  #89
gregr09's Avatar
non-MB
Interesting. I couldn't distinguish a difference. I'm glad you did though.
Old Jun 13, 2007 | 08:24 PM
  #90
drexappeal's Avatar
It's during the higher RPM's on your rev's. You can hear the muffler more.
Fortunately for me, I acheived this type of sound with my Kleemann muffler on my 230KSS w/o removing the resonator.
Old Jun 15, 2007 | 01:45 AM
  #91
sim_benz's Avatar
ok, after getting the res deleted, I can firsthand say...DO IT!!!! Its friggin AMAZING. thats all.
Old Jun 15, 2007 | 01:58 AM
  #92
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
told you so !!
Old Jun 15, 2007 | 02:10 AM
  #93
sim_benz's Avatar
all hail the mighty Saprissa, i shall never doubt you again!
Old Mar 8, 2008 | 08:19 PM
  #94
c230K415's Avatar
AMG GTS
Originally Posted by advans
IMO,
but....the I4 with secondary cat delete sounds sick. I love it. Stillkickin has done that.
I know this thread is way old and buried but I just did a res. delete today....and I guess I'm one of those people that don't notice a difference...but some people say they notice slight droning in the cabin (not annoying though). I was wondering...is there a video/sound clip of the M271 motor with secondary cat delete that advans mentioned?
