Sprint Booster or ECU Flash?
Old 06-10-2007, 09:51 PM
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by Phin
Guys I didn't want to start another thread about SB's,so I'll ask my question here(I did search for sprint booster problems = 0).
I recently purchased(2 weeks ago) a Sprintbooster (from AMGSC,Robert,real nice guy and has a sweet C55) anyway I've been too chicken s*** to install it my 05' 230.On Saturday(on the advice I got from Robert when we meet) I visited STATUS in MB and spoke with Jesse,he mentioned that the SB has cause a few problems(I asked) like transmission lock up.So my question(s) is have any of you had any Sprint booster related problems since you've installed your booster? He(Jesse,also a nice guy) said they(STATUS) could "flash" my ECU and get a little bit better performance(approx 15 hp) out of my car,have any of you had this done by STATUS and what were your results.
I would appreciate any input/advice you guys can offer.
thanks,
Phin
That's cool. So did you decide what you were gonna do? The guys at Status are really good guys. I've visited there a few times here and there.
Old 06-10-2007, 10:03 PM
Phin's Avatar
06' BMW M3
I drive by there all the time(work),so I figured I'd check them out.thanks
Old 06-10-2007, 10:22 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
I agree. Status are really good guys. I spoke with Jesse and Rick @Status about ECU Flash as well. I haven't heard anyone has problem with Sprint Booster.
Old 06-10-2007, 10:30 PM
Phin's Avatar
06' BMW M3
Originally Posted by gregr09
The only problem I've had is decreased gas mileage due to a heavy foot. I've had my SB for 9 months now, no problems other than gas...
Good to hear you've had no problems. thanks for your input man.
Old 06-10-2007, 10:41 PM
pugguy2001's Avatar
2016 C63s AMG
Does Status flash the ECU through the OBDII port?
Old 06-11-2007, 01:44 AM
valexv's Avatar
02 cl203
has anyone used evosport's powerchip?
Old 06-11-2007, 01:50 AM
  #32
valexv's Avatar
02 cl203
found this on ebay in germany, not sure if many of you could read this tho,
http://cgi.ebay.de/Mercedes-C-220-CD...QQcmdZViewItem
Old 06-11-2007, 11:35 AM
  #33
Midnight Koop's Avatar
CL203
"Brand-new technology: small, simply and efficiently directly of Germany largest Tuning-box manufacturer! High-value connectors, watertight spilt"
"Data leaf:
Four cylinder diesel engine, electronic Common-Rail injection, Abgasturbolader with drawer air cooling, regulated exhaust fume repatriation and Oxidationskatalysator in row ahead along incorporated"
"SPEED-BUSTER® Rail-K: The pricebuster!
SPEED-BUSTER® Rail-K Tuning-boxes ultra-modern addition-electronics to the simple and efficient performance improvement are for current Turbo-diesel-vehicles. Already multiply proved, worldwide in the use and for many hundred different vehicle-models available.
Motor achievement (until plus 30% Kw Hp) and torque (until plus 25% Nm) clearly are increased, the reliability remains unchanged. The consumption can be sunk according to method around up to 20% by the more efficient fuel-utilization.
SPEED-BUSTER® Rail-K: In few seconds inside!
SPEED-BUSTER® Rail-K Tuning-boxes can be incorporated into many vehicles in few seconds:"
"Remove simply the motor-cover, seek Common-Rail-pipe, draw-off Raildrucksensor connector, ... "
"...Stecker on the SPEED-BUSTER® Rail-K cable attach, attach Rail-K cable on Raildrucksensor... "
"Secure ...Tuning-Box in the engine compartment, mount motor-cover again - ready! "
"What does the SPEED-BUSTER offer® Rail-K Tuning-box?
* Most modern technology to the unbeatable dealer-directly-price
* maggot in Germany: Top quality directly of the manufacturer * compact construction with
robust plastic-housing
* watertight spilt
* aimed modification and optimization of the motors-controls-parameters
* until ca. 30% more motor achievement
* until ca. 25% more torque
* until ca. 20% less consumption
* high-value stuck connections
* straightforward installation in few minutes
* only sticking, no soldering
* problem-free, residue free back armament always possible
* Tuning-Kit is subsequently again relative cash
* durable reliability
* Notlauf- and motor protection programs function unrestricted
* no intervention into the motor tax device: work page adjusted manufacturer-parameters do not be preserved
* Tuning gets lost through Steuergerät-Update in inspection
* no adjusting compel: SPEED-BUSTER® Tuning-boxes are of our technicians optimal parametriert
* 2 years manufacturer-guarantee"
and some other stuff...
Old 06-11-2007, 01:10 PM
  #34
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
I'm not looking to gain power on my 06 c230 auto but I just want a solution to fix the throttle response lag on my car. I've searched and heard that Sprint Booster will improve the response, and the ECU Flash will be able to fix the response too plus more HP. What do you guys think? Should I get the SB or ECU?
Before you do anything, try the Drive by wire throttle reset.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Throttle becomes more responsive, especially if prior to that you were driving gently, trying to save some gas, as it "learns" what it thinks you want all the time.
Old 06-11-2007, 02:54 PM
  #35
valexv's Avatar
02 cl203
that chip from germany sounds good, runs a lil over $100. wonder if they would ship to us.
Old 06-11-2007, 06:06 PM
  #36
pugguy2001's Avatar
2016 C63s AMG
If I am reading it right it says its for Mercedes diesel engines? Try to contact them and see if there is one like that for our gas engines.
Old 06-11-2007, 09:22 PM
  #37
SlvrC230SS's Avatar
Oh yeah, that's what I tried before looking for the better solutions. This method works, but I want something more responsive.
Old 06-12-2007, 07:48 AM
  #38
esemes's Avatar
2007 c230
Is this applicable for 07's?? just curious
Also, do you leave the key IN for the 2 min. wait??
Old 06-12-2007, 10:00 AM
  #39
CL203
i dont think it makes a difference how you were driving previously... i think this just calibrates the throttle response from a blank template.
also... i thought you had to turn the key to the second "click" (i.e. the start position), not just the first "click" (the "on position"). am i wrong?
Old 06-12-2007, 11:11 AM
  #40
WaveyKat's Avatar
Something Slow
Yes its the Second Position then press and hold the gas pedal.
Old 06-12-2007, 10:48 PM
  #41
raklert's Avatar
C200K W203
should get ECU flash along with the pulley upgrade you will just waste your money getting just the ecu flash
Old 06-19-2007, 10:14 PM
  #42
Brett7654321's Avatar
Sprint Booster BDD451A
I have a new Sprint Booster for an automatic transmission, I enjoy it very much but it gives me a little too much torque. I paid $300 for it but I can sell it for $250 shipped, or best offer. Figured since everyone is happy who buys them, here's one for sale! It was on a 2005 c230 kompressor ss for about a week.
Old 06-19-2007, 10:50 PM
  #43
SlvrC230SS's Avatar
you like a little over a week late. i ordered mine already and waiting for it to come.
Old 06-19-2007, 11:33 PM
  #44
CL203
what do you guys think would give a better final gain... ECU flash and headers OR ECU flash and pulley for the m271?
i'm thinking if i get either pulley or headers to do the flash at the same time.
Old 06-20-2007, 12:51 AM
  #45
drexappeal's Avatar
Just wait to do the ECU flash, if you are considering getting both headers and pulley. No point of having the ECU flashed if you intend on getting another bolt-on later. If you got ECU with one of those bolt-ons and then got the other bolt on later, the ECU would not be set to account for the new bolt-on mod.
Old 06-20-2007, 06:45 AM
  #46
Yea I know I'm late, but I have one laying around for the next group of people that may want one. I watched this post and the other one on the sprint booster and thats what made me buy it, I actually thought you (slvrc230) already had yours. I shall enjoy it while I have it though, its on the car until someone shows some interest, but it definitely takes some getting used to. I have an hour commute everyday and half of that is traffic, and the traffic made me sketchy about buying it but, a. it's a little too much in traffic, have to break immediately (lol), and b. but it's really a lot of fun because if the guy next to you steps on it, your already WOT and gone! So I just put it out there, anyone can contact me if they need a sprint booster, but until someone does, I will enjoy it.
Old 06-20-2007, 07:20 PM
  #47
WaveyKat's Avatar
Something Slow
So true!!! am looking around to get a set of headers then ECU Flash
Old 06-25-2007, 08:13 PM
  #48
SlvrC230SS's Avatar
The wait it's finally over. I just picked up the SB at DHL. I'll install it tonight after I got home. Can't wait to feel the difference. I hope I don't get pull over by the po po. =)
Old 06-25-2007, 10:24 PM
  #49
SlvrC230SS's Avatar
Damn........ feels a lot better. I installed it like in 5 min. Drove it around for a bit and loving it.
Old 06-25-2007, 10:47 PM
  #50
Phin's Avatar
06' BMW M3
I've had my SB for over a month now,but I'm too chicken **** to install it(worried about F-ing something up).Let me know if you experience any problems.Good luck man.
Quick Reply: Sprint Booster or ECU Flash?
