Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Remove Head Unit
Step by step instructions for do-it-yourself repairs
DIY: Head Unit install / W203 ('05+) Center Console Removal Instructions
Hello, new to this forum
I bought the aux audio cable today, without fully researching the installation.......... It's for a 2007 c230....
couuldn't find the white harness on the passenger side... did you have any further luck determining if it is possible to add in the missing wire??
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
sanf,
great thread and DIY pics. That's the way it should be done.
This same process was demonstrated in a thread a few years back for the 01-04.5 MY head unit removal. Unfortunately, many of those photos have somehow turned into dead links, because people move on, and change servers and what not. I hope somehow the pics are saved on this thread for many years to come.
I had a few very useful DIY threads with many OEM installs back in the day, but unfortunately, the pics are still linked on the old MBWorld server, and now all I see is RED X's.![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
anyway, GOOD WORK![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Carlos
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Saprissa@aol.com
anyway, GOOD WORK
Carlos
Saprissa@aol.com
2011 C63
Thanks for the response.
Do you know if the "mid wire" would be an easy thing to remove??..... ie. would it be worth my time check out any salvage yards to see if they could pull the wire from a potential w203 between 05 to early 07??
Petterbizga. if that's what you really want, go for it. just make sure the ppl at the yards know what they are looking for.
Saprissa, now you have more reasons to work on some new mods/DIYs
pics request ~~
anyone got pics of the back of an 05 or 06 w203 HU with wirings plugged in? (nav unit or normal HU are both fine)
thanks,
Sanson
thanks,
Sanson
#32
Can anyone tell me if taking the HU out of an '03 model is much different than this? I assume there are some differences from the comment about not being able to use an '05 HU in an '04 model ....... but maybe the difference is just in mounting hole locations or something?
#33
2004 C32 ///AMG
#34
FM Antenna
Great DIY. I spent two hours today prior to finding this and I chickened out after the vents were removed. One question before I go at it again. I see two black wires that look like they both could be the FM antenna. Is one the antenna wire and is the end that plugs into the radio universal?
#35
Outstanding Diy!!!
Much respect to ya on this one. Very much apprectated! I was looking to hardwire my V1 and Magellan 4040 to the lighter and this post will REALLLLLLY help! I shows a simple way to access the lighter along the way to your getting to the H/U.
#36
Help removing center console w203
Can anyone give me some guidance in removing the center console on a 05 c230. I have installed the ipod aux cable to utilize an ipod through the existing hu, but i don't want to route it into the glove box. Thanks.
#37
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
#39
MB E320 2005
If you have any photo on removing the head unit from E320, please post o r email me. Thanks again.
#40
additonal info if you are interested on putting in an aftermarket HU
from thread AVIC-D3 installed on an 05+
also, Metra 99-8712 is the radio trim kit that will fit any 05+ w203, it comes as single din so you will have to mod out the pocket for a double din HU.
Sanf, you used the Scosche SCOVW03B and the back of your radio/harness looked exactly the pictures in this thread?
#41
2005 Obsidian Black C180 Kompressor - Elegance with Sports Pack
I'll be doing this to insall the Sat Nav Comand unit shortly. Does anyone know if the cradle (wires) from the old Head Unit will plug straig into the new unit?
#42
Super Moderator
#46
Nice DIY on getting the system out. I just installed my MB Ipod integration system last week and used these DIY pics. I appreciate it and now enjoying my IPOD in the car.
Thanks Sanf![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Thanks Sanf
#49
Great DIY and thank you so much. I just took about 3 hours to do this. Yeah I took a bit longer than most people would, but I was relaxed and wanted to make sure I didn't break anything..
My 07 that I bought in Oct 06 did not have the white connector on the passenger side sill.
Another couple of tips are to zip tie the cable to the back of the HU so you don't pull it out after a few tugs on the cable when you are routing or later on.
The other is that the pin spacing on the back of the HU is the same as an IDE cable in your computer. So if you have an extra IDE or floppy cable around you can use a razor knife and cut it down to just a 2x2 size, 4 pins total so it will fit on the back of the radio. Just cut off one end and leave about 6-8 inches of the grey ribbon cable to use to connect to the 3.5mm cable. Make sure you solder the 3.5mm cable to the wires from the IDE cable and either shrink wrap or tape up the connections. And use pin 11 for - or common and 6 and 12 for right and left.
Then I ran the 3.5 cable down by the ashtray on the right side, then when it came out in the passenger footwell I just tucked it up under the center console so it would come out by the center armrest/storage until I finalize where I want it to go.
Great news is that with an iPhone hooked up this way you can use the stereo as a handsfree device. The iPhone will use its own mic and the speakers in the car. It sounds great. It is fun to play with the light saber app in the great sound of the C230 - whuuuooo, waaahhn, woooo waaa whooooo (light saber noises).
I didn't have to buy anything since I had everything in my old electronics parts bin. So cost out of pocket = $0, the cheapest mod I have done yet!
www.twoseconds.net
www.twoseconds.net
#50
2012 C300 4Matic
There IS a way to add the missing wire, you simply remove the head unit and plug into the correct pins. There is a really awesome DIY for this. Sorry I don't have the link - search the forum.
