- Mercedes-Benz C-Class: How to Remove Head Unit
Step by step instructions for do-it-yourself repairs
Browse all: Interior Guides
DIY: Head Unit install / W203 ('05+) Center Console Removal Instructions
This is the same unit in my c280, am I screwed?
http://s1192.photobucket.com/user/tjswarbrick/media/KnobInDash_zpsa07b359c.jpg.html
I'm not too worried. Ill make crutchfield swallow the restocking and shipping back, I'm good like that.
As far as returning the stuff back to Crutchfield, that's not a problem. The emailed me a return UPS label.
I found a source for w211 command systems which appear to be the same as w203 command for $167. Only problem is that they have their DVD drive in the trunk.
I don't believe the w211 system will work in the w203 I would research that some more but if it does good price.
Orange is Front Right, Green is Front Left, and Purple is Low Frequency. Since the factory amp ground is brown, the brown-stripe wires are negative leads.
Worked like a charm, but it's I've only touched the one so I can't say for sure yours will be the same.
I have a 2007 C280. All I want is to have AUX functionality. I have read *hundreds* of posts in dozens of threads. It seems that my car does *not* have the white harness plug in the passenger footwell to easily connect with an available factor aux harness.
I believe my option is to pull the head unit, and wire it into the back, as discussed in other threads.
However: I cannot see any of the pictures posted in the original (1st-3rd) comments on this thread. There is some sort of photo-bucket message instead. Anyone else have pictures that depict removing the head unit?
