Ouch - Wheel Inner Fender
MBworld Guru
white and whiter
if you have 19" and do lock-to-lock the rubber will touch the plastic shield. If you have 18" it shouldn't touch. not to mention 17".
MJ, I thought you would've popped it back in after I told it it was loose that day? could've save the $40 lol.
#35
Moderator Alumni
sweet... the wheels i got are et28 up front - I have already begun searching for a heat gun.
#44
Part should be about $20 from Duval online.
MJ50 - Did you get the inner fender fit perfectly? My dealer said that they had discontinued making the fender cover for pre-05 W203. My shop had to modify it to make a tight-fit.
