Ouch - Wheel Inner Fender
Old 06-19-2007, 11:29 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
just happened this morning...
lucky wifey wasn't driving today...
i need replcement part #...
can i replace just this side or is this one big piece?
Old 06-19-2007, 12:21 PM
BadAssC230k's Avatar
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
OUCH! Im pretty sure its just the panel. Connects from the inside to under a lil ways of the car. Part # should be on the backside/inside of it. but since thats obviously missing, I'm sure a member can provide one for you.
Old 06-19-2007, 12:23 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
wow, what happen?
Old 06-19-2007, 01:07 PM
WaveyKat's Avatar
Something Slow
think thats just a "L" shape part with 4 screws and like 5 push pins am tryin to get part numbers off oemparts but its not allowing to get the part number
Old 06-19-2007, 01:12 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
no idea...
just happened this morning on the way to work...
had to pull over and shove it out of the way
Old 06-19-2007, 01:20 PM
advans's Avatar
C55 ///AMG, 535xi
wow so it ripped???
Old 06-19-2007, 01:22 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
Sweet. Rubbing I guess you were lower than I thought after all. Im assuming that piece of plastic wont set ya back too much
Old 06-19-2007, 01:25 PM
SlvrC230SS's Avatar
guess I better make sure that mine won't come off. I have a slight rubbing when backing up and turn all the way right. Funny part, it only happen to front driver part.
Old 06-19-2007, 01:31 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
maybe this is a sign that i need to raise the car up a little...
Old 06-19-2007, 01:47 PM
mig888's Avatar
EVE
I've accepted the loss of the fender cover as "normal" wear and tear for lowered vehicles. For anyone running a low/aggressive offset and has lowered their cars - this happens. In fact, mine ripped off on the freeway, chewed up, spit out, kept going...stocked at the dealership, replaced... 3 days later gone in the parking lot - BUT this time there's enough of the covers (yes both) remaining that I'll be fine.
=D.
Old 06-19-2007, 02:06 PM
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
daaamn! that's nuts man.
sucks to see that.
Old 06-19-2007, 02:07 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
anyone w/ part #?
Old 06-19-2007, 02:20 PM
C24owner's Avatar
'08 E550 4Matic
I lost both of mine. One ripped off on the highway, the other was torn to shreds just like yours. Just go to the dealership and ask for a replacement. Once you have the new ones, take a blow torch to it to heat up the plastic and bend as much out of the way as possible.
Old 06-19-2007, 02:48 PM
mig888's Avatar
EVE
Or you could opt for the cheaper, safer, heat gun?
Old 06-19-2007, 02:51 PM
SlvrC230SS's Avatar
Hmmm, that's good idea. Maybe I'll do that to mine so I dont have to keep hearing the rubbing noise when backing up the car
Super Moderator
nlpamg's Avatar
heat gun is so salty! blow torch FTW!
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Or you could mold those pieces with aluminum or other lightweight metal.
Super Moderator
MJ50's Avatar
bone stock E55 AMG
scheduled to be replaced by my 'installer'...
Old 06-19-2007, 02:59 PM
Saprissa's Avatar
Jose to the rescue !!?!?!?!
Old 06-19-2007, 03:23 PM
sim_benz's Avatar
mine: '01 C240 w/heavy modifications dad's: '05 997 Carrera S
yeah the same day i picked mine up from getting the e63, that piece ripped off on the pass side and is currently shreddede on the driver side...on the upside no rubbing noises!
im having it trimmed and secured, so nothing flaps in the wind...but idk if im going to get them replaced...what function do they serve?? seems like they arent necessary, but someone please correct me if there is a great reason to get them replaced...
Old 06-19-2007, 03:28 PM
KleanC's Avatar
White C
This happend to me 2 months 3 ago. I just took it to my friends body shop...the guy just took a razor and trimmed it. (and my car isn't dropped) still rubs tho when i turn the wheel all the way.
Old 06-19-2007, 04:11 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
Whats your idea of low/aggressive offset - assuming this is only for the front. mj, whats your offset?
Old 06-19-2007, 04:43 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
dunno what offset but it's same as clk55/c32
the driver side is barely touching the tire when turned all the way...
Old 06-19-2007, 05:05 PM
mig888's Avatar
EVE
ET30 in the front, 18x8.5 less than a finger gap at least. Mine are long gone, but I don't even complain about it anymore - just do few small modifications. When I go lock to lock my tires are not more than 2cm to the rubber covers (if not less).
Old 06-19-2007, 05:31 PM
ronce's Avatar
c230 2005, Mods- Custom Muffs-Lorinser LM6- Tinted window-Smoked ligts- Carbon lip-Hnr Springs(Cut)-
hey..yours was the same as mine.. What i did was, adding a screw to tighten it with the bumper. And the prob goes away. =)
Quick Reply: Ouch - Wheel Inner Fender
