DEPO Headlights Thread - everything you ever wanted to know about DEPO
#426
07 C230 SS and 06 Acura TL NAV
email Steve at s_krabbenborg@hotmail.com
he is in Netherlands. the website is www.MBenzNL.com, but the online store is closed.
#427
R129, XF Sportbrake, SC400
Yes, if you put a halogen bulb in a projector it's not going to be as bright as an HID bulb. If it was so bad why would so many automakers do it? Take the ML for instance, they changed the headlight housing in 2002 to a projector type and used halogen bulbs and had HIDs available. Then if you wanna go a bit old school, when the ES300 first came out, they also used projectors with halogens.
#429
2002 c240
#430
If anyone has a broken 203 projector headlight they wish to sell for cheap, I'll
buy and open up and note critical specs and to see if any OEM HID projectors
will easily fit.
I'm just about to begin another Depo mod, fitting instead an OEM bixenon from
an E55 or RS6. I'm planning on taking pics to make a DIY for 210 owners so
they can perform this relatively easy mod themselves.
If I had a 203 headlight to open up and measure, we may be able to do same
for 203s.
( already checked my local wrecking yard - none found)
will easily fit.
for 203s.
#431
#433
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#435
2002 C240 Black
I am gonna try that
Check the connection between the stock harness and the Depo headlight's plug. Make sure all the prongs inside the headlights housings are extended all the way. For some reason 2 of mine were pushed in. All i had to do was take a pair of plyers and pull them back out. After that everything worked beautifully and I havent had a problem since.
#436
2004 c230 ss
Just purchased the following
Purchased these for 240 shipped. I asked the seller if they were OEM and he said they were. I can tell now that they are non bix, but not a problem, since I was not looking for the bix for 1200+. I just like the clear look of the lenses. Now as far as HID kits, do any of you recommend any specific kits, or shops in LA to have them installed. Ive been reading and thats why I did not purchase the Ebay Depot's. Thanks for the help.
#438
W203, W211, W219, W212
Any updates on this? Has anyone purchased a set of these?
One other thing that I noticed:
Each of the eagle eyes assembly has two cells that don't have LED bulbs in it, due to the brackets sitting behind the cells.
![](http://www.303ezine.com/forums/sclass_style.jpg)
It doesn't seem the same case with the depo lights below. But I'm not sure. Would someone please clarify. Thanks.
![](http://img503.imageshack.us/img503/2663/w203ledtaildepocs6.jpg)
#441
#442
The question is (written in between the two pictures), whether the Depo lights have empty cells as well or not.
#443
MBworld Guru
white and whiter
Drex, perhaps I should clarify my question. I wasn't asking about the two empty cells on the S-Class type. I've even said in the post that the cells were empty because of the brackets (or mounting spots) sitting behind them.
note that the tail lamp cut out for the bulbs are made to fit both 01-04 and 05-07.
#446
I've actually considered trying these as well, but I like the S Class taillights, especially after I did the re-wire to have dual running lights on both sides (w/ the OEM rear foglight still working).
#447
Np. I think I like the S-Class better as well, but I really do like LED brake lights, and we all know that the eagle eyes LED quality just plain sucks. Currently I have the eagle eyes non LED, and they work just fine.
I’m still not sure whether to get one of these or not. I might, just for fun. But I’d like to read some sort of review from a user before making a decision.
#448
Most people report that the LED's start burning out after 1 year with the Eagle Eyes. For the price of OEM 05+ taillights, you can buy 3 sets of LED taillights (I doubt I will keep this car 3 years). Once my Eagle Eyes burn out, I'm going to give the Depo brand a try.
I learned about the Depo headlights the hard way. I installed them, sold em in less than 2 weeks, and bought OEM Bi-Xenon's. The Depo's actually look great, however there is a design flaw. The reflector "bowl" inside the Depo's are installed backwards at the factory. This ruins the light pattern by causing hot spots, and the light is front heavy with very little light on the sides. To many people, it's acceptable. Since I live in Ohio with a lot of rural dark roads, the light pattern was unacceptable for me.
Check out the link below. This is from a VW forum, however the VW owners were able to "tweak" the Depo lights to fix the factory design flaw to fix the output of the light. Unfortunately, the Depo's for the C Class can't be fixed easily like the VW.
Depo Light Pattern on my W203
![](http://img151.imageshack.us/img151/1131/lights2jl8.jpg)
#450
I had to go through a few sets of eagle eyes leds within a month.
The third time it happened I decided to switch to non led.
