Do I have to realign my wheels when I install my winter tires
Old Oct 14, 2002 | 12:52 PM
TylerDurden's Avatar
2002 C240 C2,C4,C5 Clear Bra, Bose, Pinstriping
Folks,
I wanted to find out if it is absolutely necessary for me to re-align
my wheels when I install my brand new winter tires for my C or is a tire balance sufficient. My current car just has 3500 miles on it and the current alignment is dead center.
I just want to avoid the extra cost of alignment at my MB dealer if it does not do much good. If you techies think it is worth it then I dont mind having it performed.
Thanks in advance.
TD
Old Oct 14, 2002 | 12:55 PM
avlis's Avatar
2008 VW GTI
No need for an alignment. Tires alone don't affect the alignment.
Old Oct 14, 2002 | 12:56 PM
young's Avatar
GLB 250 4matic
i did not. and would guess not, though.
Old Oct 14, 2002 | 01:11 PM
Buellwinkle's Avatar
Yes, anytime you change tires you likely change the outside diameter and that affects camber. It only necessary for longer tire life and shouldn't do anything odd like pull to one side. The MB dealer will give you a one time free alignment in the first year, just tell them that it pulls to one side and they'll do it.
Old Oct 14, 2002 | 01:13 PM
avlis's Avatar
2008 VW GTI
Old Oct 14, 2002 | 01:16 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
THE WAY WE ALIGN MERCEDES,THE 5 HOLES IN THE FACTORY WHEELS ARE FOR THE MACHINE HEADS.SO THE ALIGNMENT IS DONE AT THE CHASSIS NOT THE WHEELS.
SO TO ANSWER THE QUESTION ,NO YOU DO NOT NEED TO ALIGN TO INSTALL NEW WHEELS AND TIRES.
PROVIDED YOU HAVE HAD AN ALIGNMENT DONE RECENTLY
Old Oct 14, 2002 | 01:20 PM
avlis's Avatar
2008 VW GTI
Wow! I've always wondered what those silly holes were for! What happens if you put on aftermaket wheels that don't have those holes?
Old Oct 14, 2002 | 01:23 PM
DSMIT's Avatar
there is a clamping device to attacth to the tire itself,
in which you no longer align the chassis ,,,you align to the wheels
Old Oct 14, 2002 | 01:40 PM
totita's Avatar
C230 K
Does anybody know if you need different lug nuts/bolts if you install 16" steels rims (with winter tires)?
Old Oct 14, 2002 | 02:44 PM
Lynn's Avatar
Yes, you will need shorter lug bolts. I don't know the size.
Old Oct 14, 2002 | 02:50 PM
session's Avatar
2007 VW GTI
Old Oct 14, 2002 | 02:58 PM
totita's Avatar
C230 K
avlis, di you get shorter bolts/lug nuts when you istalled your steel rims with winter tires. If yes, where did you get them from?
Old Oct 14, 2002 | 03:03 PM
DSMIT's Avatar
session,,
hey thanks ,didnt know where that button was
where are you in the dc area ,,,i am in alexandria
where do you get your car serviced
Old Oct 14, 2002 | 03:10 PM
avlis's Avatar
2008 VW GTI
I don't have steel rims. Young and (maybe) Tommy do.
Old Oct 14, 2002 | 03:21 PM
session's Avatar
2007 VW GTI
session,,
i see you found it before i posted a keyboard map.
i'm in fair oaks; i get my car serviced at euromotorcars. i have nothing but recommendations for them.
Old Oct 14, 2002 | 08:30 PM
Blueice's Avatar
2002 C320
U should get the blot from the shop who sold u the wheel I got my 18" and they give me the bolts for free =)
