Bi-X Igniter replacement / disassembly DIY Guide
I took the bumper off my 2k1 c320 for the first time to get at the headlights. The information display has showed a malfunction for the right headlight for at least 2 years now.
Swapped ballasts and put it all back. Right HID is still lazy and fires about 60% on first try.
Anyone know the OEM part number for the igniter/bulb assembly? Better yet, anyone know if the same parts from an CLK, S-Class, E class will plug and play?
Thanks!
but when ever i turn on the car after 20 seconds the lights flicker like crazy driver side then passenger then driver then both etc.. no idea what is happening
the hids are not attached tot eh battery there attached to the halogen output
i heard things about a calbraitor or taking to the dealer ship wtf do you do???
Either go to the dealer and have the vehicle recoded for xenon present, or order a pair of error cancelers which are $40 from us.
Aftermarket HID kits draw less voltage then a standard halogen bulb, this makes the vehicle think that the bulb is out since the draw is not there. That is what the error cancelers do, they act as a draw of voltage.
James
877-422-4736
think im starting to freak out, the dealership guy was saying that aftermarket hids wont ever work with your car properly and even with that reprogram it will still short the system out and mess it up.. wat the hell?
wow this is hopeless the guys who sold me the hids was supposed to do the install i called them and they said it must be a relay thing?! wtf!?
I am pretty sure you'll just need to take care of the coding (Happened to me as well)
GL
turn on your HID first before turning on the car and the lights will stay on. It'll still give you error msg, but the lights should work.
lastly, go to dealership and tell them they're full of **** for not wanting to change the setting. The OEM xenon or bi-xenon works the same way as aftermarket. power > ballast > bulb. it's just OEM are packed up nicely without wires dangling.
surpisingly i reconnected the HIDS and left them on with the car off for a minute then turned the car on, surpisingly the flickering still occured but no errors and no turning off, course this is only side (the driver) im gonna try put in the passenger later and see if it works to
