Bi-X Igniter replacement / disassembly DIY Guide
Some months ago I changed the ballast 2 times (2 ballasts from my brothers wrecked sport coupe) and it still flicks.
I changed the bulbs (6200k) from right to left and also with other used bulbs I have laying around (OEM 4200k) and it still flicks!
Could be the igniter having problems again!?!
PS: The price of the igniter went up since 4 years ago, costing now more than 100€!
I already wrote about this in another BIX thread. Search "2003 C230 factory HID, need ballast", thread started by Taiwanese. I wrote more details there, and posted pics there too.
Order part AL 1-307-329-076. I don't know the MB part number, but VW, Ford, and Volvo use these units too. Get a used one from eBay or wherever, and be sure the seller includes some 20cm of cabling from the harness. Just cut the old wires and splice the new wires in. You also need to chop off the old igniter connector (2 rubbery cables joined to the red bulb base).
Not only do these work flawlessly (strike voltage is 30kV compared to 25kV for the stock units), but they also fit perfectly into the OE (coupe at least) headlight assembly. You just have to clip off 1 tab on the igniter puck.
All this can be done by reaching through the cover. No need to remove or open the headlights!
After going though 3 igniters (the box with 2 cables thing), MBenzNL sent me one of these and it worked. I use these on both sides now. 0 problems after installation, and one side is coming up to 10 years.
Just ask the seller to include the connector and maybe 15cm of wiring. That's all you'll need.
Again, I am assuming that the sedan is the same as the coupe here.
You also need to clip off the 5th plastic tab on the igniter - the one that is different from the other 4. A pair of sidecutters will do the job.
I just picked up clk55amg oem projectors for a awesome price, but I KNOW they are going to need work and I have to bake them/take them apart to clean up the inside and or paint everything black minus the projector... Should look sick.
Thanks,
-Nigel
My driver side low beam light is out, I know it is not the bulb and since the passenger side has already gone through the conversion to the 1307329076 igniter I am figuring I should try that on the driver side now as well.
The only problem is I can't find anyone selling the igniter with the 3pin connector! I have contacted several ebay and amazon sellers and all say it does not come with the 3 pin connector.
Does anybody know if there is a separate part number for the 3 pin connector? Or does anyone know of somewhere that sells them with the 3 pin connector? Haven't had any luck in my search.
Try buying an old headlight from any compatible car (doesn't have to be MB) on the cheap and snip it out.
In case anyone else has been stuck with one headlight because of not wanting to replace the ballast or whole headlight assembly like me, I thought I would share.
https://xenonland.com/product/852/wi...307329076.html
I just picked up the igniter, 3pin connector, and collar. Not necessarily cheap, but after almost a year with one headlight makes it worth it now.
