How to remove rear taillights
If you can wait a little, I'll post pics & DIY instructions. btw, it's ridiculously easy !
Drex, just to confirm, has someone already posted DIY & Pics for this ??
if so, then Wing, just needs to search. If not, I'll post 'em here in time.
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
Thank you very much Carlos, your help and generosity in this matter will not be overlooked. I had indeed searched for comprehensive information vis-à-vis this subject matter several times, but did not come up with any accommodating instructions. I was then resolute to post a topic in search for an answer.
When you get your s-class taillights, you'll se the 3 mounting screws. I believe the screws are hex screws, but just can't remember exact size.
Other than that, it's as easy as open liner cover for taillights, unscrew bolts, take off connector, pull OEM taillights out, put new taillights in, re-screw.
Carlos, if you want to DIY a taillight removal, that would be very helpful. You have permission to start a new thread with that and I'll add it to the sticky. When it comes down to it, I was just too lazy to do a DIY thread...LOL.
http://cgi.ebay.com/ebaymotors/04-05...34825293QQrdZ1
Different from these, which might need different connectors 01/02/03
http://cgi.ebay.com/ebaymotors/01-03...34835559QQrdZ1
Someone verify this.
Carlos
Saprissa@aol.com
- rear parking light only lights up on outside, not inside lights
- inside right light doesn't have any function (exception in some countries - i.e., Australia, China?)
- inside left is rear foglight (US)
'05-Present taillights are 7 pin connectors
- rear parking lights light up on outside and inside of taillights
- rear fog light is a dual filament bulb that lights up brighter when activated (i.e. 2nd pull on the light switch).
Take Paypal, will entertain offers. Thanks
