Smart Key issue
Old Oct 17, 2002 | 12:25 PM
galaxygrrl's Avatar
c230k, black, auto, c2 (let the sunshine in), Bose, leather, and CD
Smart Key issue
Hi all!
Hope this post finds everyone well!
Two days ago I was at the Airport picking up a friend and I go to start my car and the key wont turn. We try of half an hour and the key would not turn. We call MB roadside (who was useless), so we call AAA for a tow. Well as soon as AAA shows up, I try the key one more time and it turns and the car turns over (hooray!).
I drove home and my auto lights were not working and the little "S" and "W" for Standard and Wet were not showing up on the dashboard (it was just blank in the square). Parked the car and tried starting it and the key would not turn again.
Next day, I try starting the car and everything works.
Anyone have any insight into this issue?
TIA
Cheers,
Beth
Old Oct 17, 2002 | 12:26 PM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
sounds like it may need a shifter assemble,,
has anything got spilled in the shifter area??
Old Oct 17, 2002 | 12:28 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
is this just a trick to get a new key?
HEY GG, havent seen you in a while. Hopefully the dealer will figure out the problem.
Old Oct 17, 2002 | 12:30 PM
avlis's Avatar
2008 VW GTI
Sounds like a bad key (but you already knew that). Did you try your other key to see if it does the same thing? It may be worth carrying around both keys, for if/when it happens again.
Old Oct 17, 2002 | 12:33 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
speaking of smart key, I thought that the keys are programmed to open windows/sunroof when parked/locked after hit unlock once then hold down again and vise versa after park if windows/sunroof open when u hit lock and hold down remote button again all will close. Is this need to be programmed at dealer or even possible on W203 (coupe)?
Old Oct 17, 2002 | 12:35 PM
DSMIT's Avatar
keep in mind that she says some of the shift indicator display is not there ,,i dont think it is a simple key issue
you have to point the key at one of in infared windows for the summer feature to work
Old Oct 17, 2002 | 12:36 PM
session's Avatar
2007 VW GTI
this feature works on my 2002 coupe.
the coupe is the CL203, for what it's worth...
Old Oct 17, 2002 | 12:41 PM
Wheens's Avatar
'03 C320 coupe-manual, '07 530i
Got a "key" question...maybe DSMIT can answer?
I've got a 2001 C320. Am thinking of buying a new 230 Coupe. Is it possible to program both cars to use the same key?
Old Oct 17, 2002 | 12:42 PM
DSMIT's Avatar
the keys are ordered by vin #,you cant uses the same key for both cars.
that would be way to convient
Old Oct 17, 2002 | 12:43 PM
JeT's Avatar
JeT
I think DISMIT maybe right. The shifter assembly appears to control the turning of the key.
Old Oct 17, 2002 | 12:50 PM
mdp c230k's Avatar
2002 c230k
You've got to aim the key at the IR sensors on the door handles from less than 10' away for this feature to work.
DSMIT's Avatar
thats DSMIT,
right its probable the shifter
DSMIT's Avatar
yes the ir sensors have the effectiveness of you tv remote
Old Oct 17, 2002 | 12:51 PM
MB-BOB's Avatar
Admin Alumni
See Garage
GG, nice to see you're back.
Not sure I understand. Were you driving the car for some time after returning from your trip to Europe, or were you trying to start your car for the first time after it sat at the airport for 2-3 weeks?
It could be the key (do you have the same prob with the other key), or it could be the EIS (Electronic Ignition) port. There have been a few posts about faulty EIS's (across several MB models, not just C-Class). Keep in mind the EIS senses the presence of the key plugged into it. Most of the key "problems" discussed here relate to the push-button remote features (including the remote opening of windows), which are unrelated to starting the car. You can take the batteries out of your SmartKey) insert it into the EIS and still start the car.
It could be shifter related, but that would be a new fault we have not discussed before. Aside from having the car in Park to start it, I don't see where the shifter issue comes in.
Old Oct 17, 2002 | 12:53 PM
tberry's Avatar
There's an IR sensor on the door? Hmm my car is black so i may have missed it. Is it like next to the actual keyhole? I thought the remote transmit signal via radio frequency and not IR. Thanks though.
Old Oct 17, 2002 | 12:54 PM
DSMIT's Avatar
smart keys are both rf and ir,,the sensor should be right next to the pull out handle
Old Oct 17, 2002 | 12:57 PM
session's Avatar
2007 VW GTI
the keys have both RF and IR transmitters (IR is how your key works with the ignition, for example). point your key at your door handles and stand within 10 feet of the car and it should work fine.
Old Oct 17, 2002 | 01:09 PM
galaxygrrl's Avatar
Guys, thanks for the advice. It's not a bad key because I tried both. I think it's something else. MB roadside thought it was the battery, but that does not sound right either. I'm just so jinxed with this car.
BTW, Bob, I was just picking up a friend by the baggage claim. I'm off to Paris, Rome, and Florence in a week and a half. Hooray!
Ciao
Beth
Old Oct 17, 2002 | 01:16 PM
JeT's Avatar
JeT
GG, be weary of pickpockets while you are in Rome. They're sneaky in that part of the world!
Old Oct 17, 2002 | 01:20 PM
trench's Avatar
2002 C230 K
No crap, you can be standing admiring some ancient Roman artifact - the next thing you know some gypsy kid's got his hand down your pants looking for your wallet.
- BT
Old Oct 17, 2002 | 01:23 PM
JeT's Avatar
JeT
- BT
I guess some people would enjoy that!
Old Oct 17, 2002 | 04:57 PM
galaxygrrl's Avatar
I've been to Italy before, so I think it's fine. But thanks.
Hope everyone is well!
Cheers,
Beth
Old Oct 17, 2002 | 05:16 PM
MBALEX2002's Avatar
g-wagon
summer feature
reply to summer feature question:
remember this you have to hold the button down and continue
to hold the button down> it also has to be within several inches from the drivers door handle> you will see a small square
window> this is where the car picks up the information to make this work> enjoy
Old Oct 17, 2002 | 05:33 PM
DSMIT's Avatar
I THINK WE ALL KNOW THAT NOW ,BILL
GO BACK TO SLEEP
