C Coupe Supersprint headers
Its on their site www.supersprint.com under cl203
Is there a noticeable performance gain? Im sure its a royal pain to install a new header, but would it be worth it?
I just got a 2002 C230, and did an intake on it yesterday. Results were great when cold, but that metal pipe just conducts heat when its hot, made bad throttle response.
I plan on doing the asp pulley route, but should I break my car in all the way? I only got 184 on the odometer.
I would like to do the headers, but im not sure if the performance is worth it.
The biggest annoyance I get out of the coupe is that you lose so much power after a few short full throttle runs because of the intercooler getting heat soaked. I'll let you know in a week or so how the Renntech intercooler works out but I expect it to perform not only better in the cool morning but be the same throughout the day. To me, that's the next best bang for the buck after the pulley and it's pretty much risk free as you are benefitting the engine by running cooler.
As for doing a pulley kit with low miles, it will take a month to get the pulley from ASP and then maybe a week or two until you get around to installing it. By then you'll have some more miles. I was ready to do a pulley as soon as I got my car but there wasn't any around at the time.
Buellwinkle, the reason most people don't do headers is smog certifcation problems and installation difficulties.
- BT
How much are the Supersprint headers and would you do only the headers without changing the rest of the exhaust and still get the performance increase?
Sorry, somtimes I just can't help it.
- BT
If I get the headers I will probably leave the rest of the exhaust stock. I'm not impressed with the way the exhaust manifold is designed - as mdp c230k explained, headers will do a much better job of extracting exhaust from the cylinders. However, I think the rest of the exhaust is OK and only minimal gains would be obtianed by replacing it.
- BT
The only thing a supercharged engine knows is backpressure, reduce it and power goes up.
So what would you do to increase performance? Larger exhaust diameter, higher flow muffler/resonator?
That manifold sure is ugly though, might want to change just for that
Usually the cat is the worst restriction and you are correct, a catback sytem change would buy a little but probably 5 or less.
Unless the manifold is the highest restriction in the system you will see no gain at all on a supercharged engine. .... The only thing a supercharged engine knows is backpressure, reduce it and power goes up.
- BT
Didn't I just say this?
In short: change the cat restriction enough, then the catback becomes an issue, then the manifold/header *may* become an issue.
Yes, except you stated the header alone would help and that is wrong, unless the flow restriction from the cat is less than the flow restriction from the manifold, which it won't be.
engine mod fully sorted out today...got flanges welded onto the header, to replace the lame connecting piece that was included by Supersprint.
Still it was good enough to drive with till I could get to the muffler shop, but the leakage was killing the power and it was hella noisey.
So, I can say, that with the SS header, and ASP pulley,
Daaayyyymmm!
This thing is a beasty now.
Gave her a serious thrashing tonight in Bonny Doon,
which is a little out of the way place in Santa Cruz county, that has one of the best roads to go fast on around, Empire Grade. Watch out for the deer though.
Of course it's still not an M3, but damn fun to drive.
I believe the header is only rated at about a 10hp increase, but in
conjuction with Pulley and the used Remus exhaust I put on a while back,
my butt dyno says I picked up a good 20 hp.
I'm getting such oversteer, even with C32 bars.
I think maybe I'd like to fix that...
maybe a thicker rear bar?
Anyway, there was so much talk about the SS header, but not many people bought them.
Too bad. At one point it was being offered for like $650.
Not anymore.
Daaayyyymmm!
Not anymore.
Not anymore.
The C32 bars are thicker than stock and give you flatter, more neutral handling. If you think your oversteer is bad now, don't install thicker rear bars. That will only increase your oversteer.
I suggest either a lighter throttle foot to balance the chassis, staggered rims/tires to increase rear grip or a larger front bar to increase understeer.
Bob
