The correct way to upgrade the sound in your Coupe.
Old Jul 30, 2007 | 12:07 AM
noreaga0221's Avatar
2002 c230k hb
So I lucked out in having the low grade audio system in my coupe. The avic d-3 easily replaced the stock POS tape deck. Hey MB, its ****in 2001 when this car was made, did you miss the memo that tapes died in 1992?
Anyway, with the D3 in and steering wheel controls still functioning (thanks MK), the paper cone speakers are very lacking. Now, don't get me wrong, I didn't go out and buy $400 high end 5 1/4" speakers. I bought sufficient ones that are within my budget and better than stock.
1. Remove tweeter cover, srs cover, cover under arm rest and torx screw near door latch.
2. Gently pop door skin off starting at the bottom and working around. There's about a dozen plastic clips.
3. Pull up from the top of door panel to remove from window sill. Unplug the harnesses and door latch cable.
3. Remove old speakers and extend speaker cable.
3.5 Dynamat doors.
4. Make adapters, PM me for details. . Bolt in place.
5. Attach and wire speakers. Trim foam panels to accomadate dynamat.
6. Reattach everything.
7. Tune new stereo.
8. Enjoy music alot more.
Some pics.
Old Jul 30, 2007 | 08:30 PM
Blake P's Avatar
'09 A4 S Line
Nicely done! I'd love to upgrade the speakers in my coupe, but doubt I'll ever get around to it.
Old Jul 30, 2007 | 08:41 PM
2002 c230k hb
Trust me its not that hard. With those adapters and some trimming any speaker will fit. Besides suspension, its the best noticable mod.
And I'm not suprised, 'what tint should i get' gets tons of replies but when someone engineers a solution for others, it gets no love.
Old Jul 30, 2007 | 11:09 PM
mbarrad's Avatar
2005 C230SS
Very nicely done. I like your AVIC D3 install. Are you really controlling the AVIC D3 through the steerring wheel controls? Now I have to read through the AVIC D3 thread.
Old Jul 30, 2007 | 11:31 PM
rlee02135's Avatar
2004 C32 ///AMG
did you have BOSE before?
Old Jul 30, 2007 | 11:41 PM
white_w203's Avatar
is SOLD
dont forget to cust a custom made ported enclosure thats shoots into the cabin and your car will be knocking hard!
Old Jul 31, 2007 | 12:18 AM
jedcred's Avatar
'04 Mars Red C230K Sport Coupe (not Coup-EH)
The adapters you've made look excellent. I ended up using some washers, which works, but will more than likely rattle sooner or later. If possible, could you please put up an outline of the front and rear adapters so others can print them out and use them as a guide? That's really the only thing missing on this forum as to tools for the upgrade: the wiring diagrams and all that are available already.
Old Jul 31, 2007 | 02:36 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
What speakers did you use?
Also, do u have any pics of the door panels, with an eye on the inside of the rear speaker covers? I need to replace those, along with the rear speakers, since one is blown.
Old Aug 1, 2007 | 10:34 PM
2002 c230k hb
I know the pics are pretty but read the text first next time. Read the first sentence.
C230 Sport Coup; Nope, I didn't take any pics of that. The grilles are glued to the door panel though. I just bought 5 1/2 and 4" pioneer speakers. You could probably squeeze 6" and 5.5" in the back or at the very least 5.5" at both spots. The adapters I made are almost the same size meaning the same or slightly larger could fit.
mbarrad; Yep, read the d3 thread again.
