Changing Left fog light on Coupe
Old Jan 3, 2002 | 08:46 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
I got the right one in just fine but i cant getto the left one. Theres a bunch of stufff in the way. Is there a Mercedes number I can call to get help.
Tim
Old Jan 5, 2002 | 10:22 AM
C230 Sports Coupe
help
Any ideas
Old Jan 5, 2002 | 04:05 PM
patronus's Avatar
2001 C240 / 6-speed
I have done this. I put amber bulbs in my fogs as God intended.
On the driver's side, you must replace the bulb from under the car. There is a panel just below the light. There is a seam between that panel and the one under the engine. Remove the screw between these two panels and fish your hand up through the crack (no need to remove the panels). You should feel the back of the bulb and....
Good luck!
Old Jan 5, 2002 | 11:24 PM
C230 Sports Coupe
Thats what I'm doing to. Amber lights are the best in fog and rain, well at least IMO. I will have to go get a metric socket set tomorrow, all i have is standard. OOPS! Thanks man
Tim
Old Jan 6, 2002 | 09:09 AM
vinmanc32's Avatar
C32 AMG, C300 Sport
what color bulbs do they use in Europe now
Years ago, the headlights were this funky yellow and the fogs were white or amber. What color are they now? I have always liked amber fog lights, but never went through the drama to change them. Thanks for the input.
Old Jan 6, 2002 | 05:50 PM
patronus's Avatar
2001 C240 / 6-speed
The fogs take a 9006 bulb. I purchased Philips All-Weathers from Fosmo.com or Auto-lamps.com, I can't remember which. The light is not intense yellow because it there is not really a color tinting to the bulb, but some other metalizing process that absorbs much less light than standard tinting. They are awesome.
Old Jan 6, 2002 | 10:43 PM
C230 Sports Coupe
Thats the same ones that I got. I bought mine from auto-lamps.com They work very well, I had a chance to use them tonite and i love em
Old Jan 8, 2002 | 03:59 AM
Jorel C320's Avatar
2001 C320
so is it very hard to take replace it....or fairly simple??
I always wanted to do it, but it looks so complicated to find a way around the panals.
Old Jan 8, 2002 | 06:33 AM
C230 Sports Coupe
I just know how to do it on the coupe. It only took and about 15 minutws to do after I figured out what panel to remove. The big this was ground clearence. I had to drive my car up on some 1x8's to raise it up enough to get under it, or just use a jack. I would have used mine but I didnt feel like getting it out. You will need metric sockets 8mm and 11mm if i remember correctly. Email me if you need any help. there are also some pins that you can undo that will make it alot easier.
Old Jan 8, 2002 | 09:12 AM
young's Avatar
GLB 250 4matic
why didn't you just jack it up? i did that when i removed that panel to change the washer fluid. just make sure the parking brake is applied.
Old Jul 3, 2005 | 04:16 PM
reindhar7's Avatar
05' C240 4matic
How do you remove the plastic pin in the inner fender panel ? I like to pull it out with brute force but I'm afraid I'm gonna break the pin.
Old Jul 3, 2005 | 05:13 PM
DACHIGGA's Avatar
2002 CL203
One of the pins don't come out and don't need to come out. Second, even with my lowered car, I really didn';t need a jack, also, you don't need to remove those bolts. you can just bend the plastic piece outwards. I've replaced the fogs at least 6 times, going with different bulbs and colours to see how it would look.
Old Jul 3, 2005 | 11:08 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Dachigga is right. You could probably accomplish putting them in without jacking up the car. Pull the front bumper forward a little and the plastic cover down and towards you (if you're looking up at the front bumper). At that point, you can stick your hand up and in between in order to reach the fog light. To take out the bulb, I believe it's a quarter turn counter clockwise.
Old Jul 4, 2005 | 12:04 AM
DACHIGGA's Avatar
2002 CL203
Exactly.
