SAM Modules
Old Aug 27, 2007 | 12:41 AM
jmr071880's Avatar
2001 C320
Exclamation SAM Modules
Hi all, new on here with question regarding a ticking sound in trunk...
model: C320
year: 2001
my guess: rear SAM unit? brake switch?
As of two days ago, while driving, got a *FAULTY DISPLAY* message. Gas Gauge lamp came on and turn signals would not function--all else appeared okay.
Upon stopping, trunk would not open and key fob failed to open windows or unlock. Alarm also began to go off, though was able to eventually silence it by pulling *FUSE 8* I also recieved a *BAS MALFUNCTION* as well *ESP MALFUNCTION* I corrected the ESP by doing the steering wheel reset method. I checked the fuses and they were all okay... I did a factory reset of the vehicle options as well.
Upon replacing the fuse I reset all the windows and roof as well power seats. messed with the turn signals while moving the key in various positions and eventually got everything including the gas gauge to read properly. During this process a ticking noise was audible from the trunk fuse box. When the ticking slowed everything became normal again.
I've read that the SAM units may need reseting with a Star Tool. Anyone in Arlington, VA have one???
QUESTIONS:
1. Can I manually reset the SAM in any way myself? (will not be home to visit a dealer for some time!)
2. Does anyone have instructions on how to change the brake switch?
If anyone can help, it would be appreciated!!!
Old Aug 27, 2007 | 08:35 PM
SUNILP's Avatar
2015 E250D
sounds like your SAM is going out. Need to replace it likely as those commonly go bad.
Old Aug 27, 2007 | 10:04 PM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
yup... sounds like the rear sam... i had some of the same symptoms with my car when MB roadside assistance replaced my car battery... they fried my rear sam
Old Mar 5, 2008 | 07:55 PM
LuxuryC240's Avatar
2003 C240
You may have seen my post earlier today about my visit to the dealer, but I was wondering if there was a way to clean the rear SAM. It has some dust on it too, would it be safe to use an air duster on it, like you would a computer? I'm guessing it would be ok. With my luck, I'm probably going to need a new rear SAM. TIA.
Old Mar 6, 2008 | 03:55 AM
rubensans's Avatar
Brabus K3
I'm Sorry.
Same has happened to me yesterday.
Rear SAM KO.
Seems that new SAM has this problem solved.
Old Mar 6, 2008 | 10:37 AM
LuxuryC240's Avatar
2003 C240
Originally Posted by rubensans
I'm Sorry.
Rear SAM KO.
Ruben, are you referring to the OP's problem? Or it being dirty or damp? Thanks.
Old Mar 6, 2008 | 11:10 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
sunil, is there any 'improvements' with 05 rear SAM???
Old Mar 6, 2008 | 11:15 AM
Mu9enx's Avatar
01' C32o
if i get the 05 rear sam, would i be able to activate the netherlands setting? walters mb told me my current sam didn't have this feature..
Old Mar 6, 2008 | 11:17 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
r u sure walters MB knew what they were doing???
Old Mar 6, 2008 | 11:46 AM
Mu9enx's Avatar
01' C32o
yeah, the guy that was helping me said he used to be a technician, and knew how to use stardiag. i even printed out the steps, but he told me that he done it plenty before. went to check my car about an hour later he tells me that i don't have that setting/option. i was like wtf, and he was like wtf. lol.
Old Mar 6, 2008 | 11:58 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
hmm... that's the 1st time i hear such thing...
did he say if u needed front SAM or rear SAM?
cuz i have spare front SAM available...
Old Mar 6, 2008 | 12:16 PM
Mu9enx's Avatar
01' C32o
pretty sure he told me the rear. are there upgrade versions of both front and rear sams?
Old Mar 6, 2008 | 12:31 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
u should ask steve if he can enable chirp on ur car...
Old Mar 6, 2008 | 01:34 PM
WaveyKat's Avatar
Something Slow
i have a Front 05+ SAM just waiting to be installed...
MJ did you replace your rear sam??
Old Mar 6, 2008 | 01:37 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
nah... not even sure what goodies are there for updating rear SAM...
Old Mar 6, 2008 | 01:38 PM
romz's Avatar
2001 C240
Quick questions do you guys know if the siren for the panic button is connected at all with the rear SAM?
Old Mar 6, 2008 | 04:56 PM
rubensans's Avatar
Brabus K3
I has broken reconnecting the negative (Battery). New Sam have this problem corrected.
Not sure with functions I can add with new rear Sam.
Right now the car is on the stealership.
Old Mar 6, 2008 | 05:20 PM
lancemb's Avatar
03 c240
what was your grand total if you dont mind me asking for replacing the rear SAM anyone?
Old Mar 6, 2008 | 07:04 PM
LuxuryC240's Avatar
2003 C240
I have been searching and reading about it because I have a strange feeling I need it replaced, but the technician told me it runs close to 500, but I know thats a steep price, because I think people on here mentioned prices in the 300s or so in some of the threads that came up in searches....
Old Mar 7, 2008 | 03:37 AM
lancemb's Avatar
03 c240
ouch 500 sounds very steep.
Old Mar 7, 2008 | 08:26 AM
WaveyKat's Avatar
Something Slow
$500 is alot i got a Front 2005 SAM and Headlight washer with all the wiring and Parts for 350 shipped!
Old Mar 7, 2008 | 01:03 PM
rubensans's Avatar
Brabus K3
Here in Spain 272,78€
Old Mar 7, 2008 | 02:12 PM
LuxuryC240's Avatar
2003 C240
Yeah, I agree thats steep, if need be, I'd buy it somewhere else and have my local independent install it, but many of the online mercedes parts websites are not showing it in their catalogues, can anyone suggest a place where I'd get this if I end up needing it? For a 2003.
Old Mar 7, 2008 | 07:42 PM
lancemb's Avatar
03 c240
i have the same year and chassis as you. i will also look around and ill let you know.
Old Mar 11, 2008 | 03:25 PM
ponch's Avatar
2000 E55 AMG, 2009 ML320 Bluetec
Found this post today - my 2001 C240 is currently being diagnosed for same issues after I replaced battery. I'd be interested if anyone found them online or a supplier rather than going through the dealer. Quoted at $530 Canadian for a new one before labour.
Thanks,
Rob
