Brake Pad Warning
Old Sep 9, 2007 | 02:06 AM
pmb600's Avatar
E550 4MATIC
Originally Posted by BlackLiquorish8
i bought my car at 40K last summer and i have close to 60K now still on the pads that were on the car when i drove it off the dealer lot. the car def doesnt stop as well as when i first got it but the light isnt on yet i might just wait to change them. does anyone know how much indys charge to change the brake fluid?
I don't know what an independent would charge, but I paid $110 for a brake fluid flush at the dealer. That should be done every two years regardless of mileage.
Old Sep 10, 2007 | 06:41 PM
Replica's Avatar
2003 C240 6 Speed
Originally Posted by drexappeal
You're not the one that soldered the turbo kit are you? That thread is getting so much attention and I was almost embarrased to hear a MX-6 owner did that.
haha, fortunately not :P that guy is a definite embarrassment for us, but he's got a second gen mx6 and he's from Australia.
Old Sep 10, 2007 | 07:01 PM
c230K415's Avatar
AMG GTS
Originally Posted by Moviela
The ABS system has a lot of narrow passages that are the reason special brake fluid is used in Mercedes cars. You don't want to fill these with dirty brake fluid. Opening the bleed screw when resetting the pistons will dump most of the dirtiest fluid out the bleed valve. It is easier to reset the pistons with the bleed valve open. You won't be forcing fluid backwards through the ABS/Master cylinder to the tank. If the tank had been "topped off" (which you should never do) resetting the pistons can force fluid like a fountain out the vent hole in the tank cap. Brake fluid will instantly eat automotive paint. Never ask me why the inside of the hood of my Porsche had to be painted.
You do need to change the brake fluid every two years because of copper absorbtion. This will also get rid of the dirt and water in the fluid.
So does this mean I can still trust a indy to take good care of changing my brake fluid (supposing I supply the brake fluid)? How much brake fluid would it take to do a change?
Old Sep 10, 2007 | 09:13 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Yup. I think there were like 50 different forums poking around mx6.com after that. I really miss my 2nd gen. I was on the verge of putting a KLZE in it, but decided it was too much of a hassle at that point.
Any problems with the w203 are nothing compared to the MX-6.
