need help with climatronic
I bought this C320 climatronic from a guy and I can't do the tunnel mode where you can close and re open all your windows and sunroof by holding the air recirculation button? I have a c230 and I know the original climatronic can do it because I play with it all the time. Can a C320 owner confirm about this? I mean a c320 climatronic can do a tunnel mode right? Thanks.
If so, understand that Climatronic only activates existing "one-touch" auto-close/open features already in the car. The sedans have one-touch close for the sunroof (where fitted), but my understanding is that the Coupe doesn't have one-touch close for the Panorama roof. So, Climatronic won't be able to work the Pana-roof as it does the sunroof in the sedan. At most, it'll cycle the windows in the doors, only.
I'm no expert at this. Someone else have an opinion?
Is it supposed to be connected to a vehicle equipped with separate fans for each of the front passengers? If so, and I put the unit in a C240, which I assume only has a single fan for both front passengers, what will happen? I seem to recall reading something about this unit controlling two fans. Is the second fan for the rear passengers? Does anyone know where this second fan is supposed to be mounted. Any idea if the second fan can be fitted into a C240. Is the C240 already wired for the fan (since they are basically the same car with different engines and options?
thanks!!!!!!!
Jim
I think you're saying that you have bought a Climatronic unit and have installed it in your C230K... but it doesn't work?
i don't have the digital climatronic unit. xcfisher has it - http://www.csportcoupe.com/forums/sh...=&threadid=824
btw the 02 coupe doesn't close the roof in tunnel mode. 03 does.
Sorry… have to chime in every now and then…
Nice to see you here, Bos. The 2003's don't have one touch close for the roof either, but the tunnel mode works.
But it is good to check in every now and again. Glad to see you're still hanging in there as well.
