side mirror drift
Maybe before then I will try my door slamming theory.....
While we are on the topic, this is what I have:
C240 - 6speed
Glacier White/Java inserts
C1
C2
C3
C4
Bose
Multi-contour
Xenons
CD Changer
Love it.
I have a manual tranny, so the argument of the automatic moving the mirror as is passes through R may not be the entire cause. Besides, there is a delay (1 sec?) between the time R is engaged and the mirror moves.
Yes, I have C1 package. Otherwise, I would not have this problem because I would not have memory seats.
C1
Oh well, at the time I was being "frugal"
I do have the convenience setting moving the steering wheel, but not the seat when I exit the vehicle. I don't know if this plays a role in the problem.
I also notice that when the drift does occur I have to push the memory button twice to get them to return to the programmed position.
I have not reported this to the service folks yet because, as indicated by someone else, it is not at all easy to replictate.
If anyone finds the magic cure, myself included, please be sure to post the findings here.
Thanks to all for a very interesting and informative board.
JR
Will be taking the car in for it's first service here soon....will have them check it out. It seems more like a nuisance than a major problem.
jnjrowland, I'm not sure if this is fact or not, but once the car is running, it seems like you have to press and hold the memory button in order for the seat/mirrors to move into place. If you just tap it once, it does not move all the way (at least on my car). I was thinking that this may be why you have to press it twice.
speaking of memory, I have my car set so that when the key is removed both the steering wheel and the seat move up/back. The strange thing is that only the steering wheel moves up, the seat stays in it position. (I dont have my seat very far back either). It does work, if i move set the seat to a closer postion, then both the steering and seat moves up/back and when it move back it moves back farther than my normal seating position.
BTW: I am only 5'7 so, as you can tell my seat is not postioned very far back, but i guess the convience feature is ideally for someone smaller who has there seat at a closer position....unless this is a problem that is only on my car, than perhaps I should have it looked at. Anyone else notice this?
Count Me in, My 01 C320 does the same thing. It tends to mostly happen on the driver side, the mirror usually drifts down...probably about 1/2. I turn my passenger side parking tilt mirror off, so that side usually says where it should.
