HID Fogs
2007 ML500
HID Fogs
Hey Guys,
Does anyone know if the fog lights on our vehicles are monitored by the computer to inform us of a burnt out light bulb?
I am thinking about installing a HID kit for my fogs but again there is the 35W HID kit to the 55W halogen problem I am worried about again.
Thanks.
Thanks.
Super Moderator
the computer does monitor the fog lights and shows bulb out errors if a bulb goes bad.
it depends on what HID kit you get for the fogs as to whether or not it will show an error.
'08 E550 4Matic
2007 ML500
Bummer! I guess I'm just going to stick with the halogens then. The reason I was considering HID fogs was because I have an extra H7 kit right now but I can purchase a pair of 9006 bulbs and re-use the ballast/ignitor. However, the extra kit that I have gave me an error message when I installed it in my headlights so I had to install a relay and a resistor to bypass the computer and stop it from flickering. All this seems like a little too much work for my fogs and I'm not sure if I want to wire everything up again... what a shame.
Anyways, thanks a lot for the replies guys!! I appreciate the help.
consider reading up on the capacitor trick....and seeing if it can be applied here?
Is @ Home
I dunno about most people but when my alarm goes off the fogs flash (bad for HIDs). That and I like to keep my entrance/exit lighting since its not a feature on most cars, not on the fogs atlease.
2003 C240
If the HID doesn't work in this case, I'll always stick with the halogen, because this feature is one of my favorite...I get most of my looks with this feature along with the puddle lights...
Super Moderator
as for the entrance lighting with the HID fogs, it works perfectly and the HID fogs look waaaaaay better than halogens for that purpose... the HID fogs make the entrance lighting look way more impressive.
Is @ Home
dude, how often does your alarm go off? that isn't even an issue to me.
The HIDs did make a nice looking entrance/exit light. I got no issues with the exit light but when I unlock my doors at night it takes me less than 5 seconds to walk into my door. It was pointless for them to turn on for that long and shut off.
2003 C240
The only time my alarm has ever gone off, it was inaudible, and would not turn off, because there was an issue with it when I took delivery...so I've never heard my alarm...
1 Post
03' E39 M5, 10' CLS63 AMG
but a question, i turned off my feature for entrance light because i thought the constant turning on and off of the hid's may not be a good idea? would it effect the hid if i had that feature on?
thinking about it every time i walk to my car at night and un-lock they will turn on and then turn right off as soon as i open the door? and then when the car turn on i turn fogs on again. followed by the same thing when the car turns off???? so is that not too much stress on the hid bulbs? ????
Good question, Im wondering the same thing and hoping a get a HID FOGS from Carlab soon.
Also, exact same thing happens to my low beam HIDs whenever I pull into the garage in auto. The HIDs will flick on for a brief second because of the sensor... then I turn off the car.
Im too lazy to switch out of "auto" and remembering to turn my lights "on" everytime I drive at night/fog/caves/underground and "off" everytime I park (way 90s).
Idk, maybe if I get HID Fogs, Ill be so accustomed to driving with fogs on at night and submit to flicking them on and off (no fogs in auto)....therefore saving my lowbeams when I enter the garage.
Choices to make..
Choices to make..
Super Moderator
I've been running my HID fogs for I think a little over a year and a half. I leave the auto mode on and and do use them while driving and even during the daytime. They're still pretty good...
Is @ Home
i have hid fogs in my car and truly love the look and the extra light on the road at night.
my 99 E320 doesn't turn on the fog lights upon entry so it's only an issue
when exiting the car after using the headlights. but the solution isn't too
painful here either: after engine shut off, with headlight switch OFF,
manipulate ignition key to position #2. then, key back to #0 and exit
vehicle. fogs (courtesy lighting) will stay off.
C320 Coupe
if the HID kit flickers after install, you can do some re-wiring to make them not flicker, donno how to do it in detail, but i'd suggest you to get some professionals to do the installation, it requires taking off the bumper anyways, which is not an easy work
i need bigger.
