Help! my MB is acting strange!
Has anyone here had the same problem??
Thanks in advance!
ps.
I have a confession: Prior to the trip I didn't put the premium fuel in my benz! Could this be the problem??
Good luck!
Good luck!
The EGR valve only opens on decel, and if it does not snap shut it will cause the engine to idle very rough, you should not loose that much power though.
A plugged cat will cause all your symptoms, both will cause PO300-O306 missfire codes.
Airmass faults can also cause misfire codes, but be careful in your diagnosis.
Cleaning it can cause more damage. Rebuild units are now available for about $200.00
I bought a set of torx security bits but they are the wrong ones. I think the ones I need are 5 stars, and the one I bought were 6, so that didn't work.
Is it possible to unplug the connector without having to take the two torx screws out??
I will try to eliminate possible solutions one by one, so right now I am going to stick to checking the MAF. If that doesn't fix it, I will consider one of your others suggested solutions!
This seems like a common problem in C class, so I will keep everybody posted on my progress!
Thanks for all your responses!
I am searching now for the best price of a MAF.
When I unplugged it, it almost seemed as if the problem got worse... Maybe it was just me, but it sure didn't help it.
Any other possible causes for this problem?
I got a Magnaflow cat recently for 300 installled.
MBZ price for the part was 1500.
But like someone said, maybe a warranty item.
Look around the exhaust pipe.
See any grey dust?
Mine was spewing it in the end....
How many miles on your car?
As far as premium goes, I've had many loaners, and the normally aspirated engines run fine on lower octane.
My car only had 87 octane once, and it ran with the timing very retarded, but no CEL's.
Will the cat be covered under warranty even though it has over 80,000 miles on it and is under 8 years old??
BTW, I think the regular MB warranty expired!!
The symptoms of the car are: when at idle the car vibrates, and when I step on the gas pedal, the engine sounds like it's "choking", and my biggest problem is that it lost power - probably by half as much.
The codes read missfire on cylinders 1,2,5, and 6.
thanks for all your replies!
I am taking the benz to one of the local shops, and I will see what they tell me tomorrow... I am keeping my fingers crossed, but at this time I don't think it will be anything cheap!
